Removing EGR walls in TPI
Car: 1992 Camaro RS
Engine: 5.0L TPI
Transmission: 5-speed
After reading the post "Create Better Air Flow for TPI Plenum" in the FAQs, I'm seriously considering having the shrouds in front of the EGR holes machined down. What are the pros and cons of doing something like this?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Removing EGR walls in TPI
No cons , the pros better flow. if you look how much the hump blocks entering air flow for the first 3/8 inch of throttle movement.
Car: 1992 Camaro RS
Engine: 5.0L TPI
Why would they put the humps there in the first place? Any estimate as to how much it might cost to have these machined down?
Engine: Lb9
Transmission: M20
Get out a carbide bit and grind them down. They were installed as a dividing was between the egr ports to help block and blend the exhaust gasses. Its not like your in for a huge butt Dyno gain !.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1992 Camaro RS
Engine: 5.0L TPI
Awesome did you do that yourself or have someone do it for you? How much power did you gain? Also, what is the stock throttle body size? Is it 52mm?
Car: 82 Z28
Transmission: T400
1992rs/ss
Jan 31, 2025 05:10 PM
Sanjay
Aug 12, 2015 03:41 PM
