K&N filter on TPI
Old Jan 29, 2014 | 04:40 AM
Cambird Z/AM's Avatar
Car: 1991 GTA Trans AM
Engine: 305 TPI V8
Transmission: 4-Speed Automatic (700-R4)
K&N filter on TPI
Would anyone know the part number for a K&N air filter for a TPI 305? Preferably the filter that bolts to the throttle body directly, not a factory replacement, or does it even exist?
I've tried to look on online and I must be looking in the wrong spots
Any help would be great, thanks
Old Jan 29, 2014 | 06:06 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Re: K&N filter on TPI
http://www.knfilters.com/universal/unique.htm
I wouldn't do it though. You would be sucking in all the hot air from the engine bay.
Old Jan 29, 2014 | 06:17 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Old Jan 29, 2014 | 06:18 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Old Jan 29, 2014 | 06:23 PM
ZKing28's Avatar
Car: 1990 Iroc-Z
I think gutting the airbox under the air filters is a better choice. I'm just debating about keeping the aftermarket filters or going back to stock ones.
Old Feb 2, 2014 | 01:34 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I gutted my box and use two sets of KN filters. Bought one set new for everyday and another set used as a spare set just in case.
Old Feb 2, 2014 | 03:08 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Supposedly it reduces your e.t. by two tenths of a second in 1/4 mile, pulling in the hot hair, but I have ceramic coated headers, which reduces temperatures by a lot! They make two models, one that I use, & a bigger one.
Old Feb 2, 2014 | 03:22 PM
ZKing28's Avatar
Car: 1990 Iroc-Z
That's a good idea. I was speaking of whether stock air filters or aftermarket like k&n filters were better. I was doing some research about how the k&n filters are better flowing, thereby they let more moisture and dust into the TB and so on. At least that's what i read in a couple threads here. I have aftermarket filters right now that I want to clean but I don't want to damage the engine if I don't do it properly, so I'm thinking of switching back to OEM factory filters to protect the engine.
Old Feb 2, 2014 | 03:28 PM
87rattler's Avatar
Car: 87 Iroc-Z28
It's not so much header heat as it's the air blowing through the rad.
Posted from Thirdgen.org App for Android
Old Feb 2, 2014 | 04:19 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
It's not difficult to clean them properly. Just takes time. When I cleaned mine I washed it using the cleaner twice. Let it dry for a day. Then sprayed the oil in the recommended amounts and let that dry for 2 days. Never had a problem. I have a spare Specter filter so I can take as long as I want.
Old Feb 2, 2014 | 05:53 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Well I like the K&N on my Camaro and being carb'd, seems to run great with it. Now on my 2001 Explorer Sport I put in a stock paper filter as I noticed the sensor filament kept getting dirty. Can't say it was from K&N, but problem solved once the paper filter went back on.
Old Feb 2, 2014 | 06:00 PM
ZKing28's Avatar
Car: 1990 Iroc-Z
I suppose if I take my time then I shouldn't have a problem. I still have yet to completely gut the airbox as well, took off only one piece of the silencers on each side.
Old Feb 3, 2014 | 11:13 AM
RandyKoontz's Avatar
Gut the boxes, it was the difference between barely chirping the tires on the 1-2 shift, and breaking them loose in my old lb9 5 speed '88 IROC. BTW, I never had any issues w/ the K & N filters.
Old Feb 8, 2014 | 07:40 PM
Solders18's Avatar
Car: 87 Iroc
Engine: 5.7L TPI
Transmission: Built 700R4
Axle/Gears: 3.23 posi
I have gutted my air box and added in "ram scoops" behind the fog lights and haven't noticed any difference on how quickly they get dirty. i am impatient when it comes to letting the filters dry. i leave them out for an hour or two after trying to get most of the water out. i've never had a problem with dirty sensors or anything. this is on a variety of motors from duramax to volt. the little tiny bit of moisture left in there is less than what the engine is sucking in on a humid/rainy day.
Old Feb 13, 2014 | 01:33 PM
Engine: Lb9
Transmission: M20
Old Mar 8, 2014 | 01:53 PM
Van Nuys born's Avatar
Car: 4/89 IROC Z28 G92 -
Engine: LB9 TPI
Axle/Gears: 3.45
I'm servicing my K&N filters now and see two cresent shaped baffels in the box with 2 screws each.... to gut the air box you remove these ?
Thank's
Edit .. I found this https://www.thirdgen.org/forums/tpi/...ke-box-vs.html
I think I'll just remove the fins......
Old Mar 10, 2014 | 05:38 PM
The best choice you make is to remove the two baffles you have identified, then cut out the bottom of the filter housings. You will feel this when you drive.
stalkier
Dec 6, 2015 11:25 PM
Thornburg
Aug 25, 2015 01:46 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
