i need fuel line
Old Feb 17, 2014 | 09:03 AM
86B4Z's Avatar
i need fuel line
Hey guys, i need to replace the send line from tank to filter. Where can i find replacement ? BTW, I have '86 LB9 engine. Thanks.
Old Feb 17, 2014 | 12:12 PM
86B4Z's Avatar
Re: i need fuel line
Anyone ?
Old Feb 17, 2014 | 01:24 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Should be able to just buy a length of fuel line (rubber/synthetic) from your local autozone/advance/etc, cut it to length and replace it.
Old Feb 18, 2014 | 03:02 AM
n2deep22's Avatar
check this to see if any apply.http://www.thirdgenranch.com/catalog/category/5353654
Old Feb 18, 2014 | 08:26 AM
86B4Z's Avatar
Originally Posted by n2deep22
This is for a TPI setup. Theres a hard line from tank then compression fitttings w/rubber line (date coded) then back to a hard line to filter (?).
Any suggestions ?
Old Feb 18, 2014 | 11:13 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Try a wrecking yard.
Old Feb 18, 2014 | 11:37 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Call up the guys at www.thirdgenranch.com I think they have some
Old Feb 18, 2014 | 11:41 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Cut the hard lines at the tank and at the filter. Leave 2-3" so you can connect a new rubber hose. Buy Fuel Injection hose, and install using Fuel Injection hose clamps. Use two clamps on each end for safety. If you really want to get fancy, there is a tool that will allow you to "roll" a hose bump into the line. Not really necessary, but just more info.
http://autoplicity.com/products/1379...FURsfgodvW0AfA
Old Feb 18, 2014 | 04:28 PM
86B4Z's Avatar
This is what the line looks like. Flare goes to filter rubber lune to tank. Im not hacking this up this is a date coded factory correct piece.
Attached Thumbnails i need fuel line-forumrunner_20140218_172632.png   i need fuel line-forumrunner_20140218_172643.png   i need fuel line-forumrunner_20140218_172654.png
Old Feb 18, 2014 | 05:40 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I just went through the same thing. I had to buy the new metal line from http://www.getdiscbrakes.com/fgl8507 . Then I made a short hose to replace the rubber part with an lines and fittings.
Old Feb 18, 2014 | 06:09 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
inline tube
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
