restoring 85 IROC
Old Mar 14, 2014 | 08:01 PM
crewguy's Avatar
restoring 85 IROC
My son drug hoe an 85 IROC last night. This car is all original an has been sitting between 2 pine trees since 1993. Is there someone out there that would rebuild the TPI to pristine condition. Can the injectors be rebuilt? IF the engine is numbers matching- should I rebuild the 305? I was told by the second owner the heads were not original. How do I check the numbers from the engine, heads, and trans to see if they came with the car from GM?
Old Mar 15, 2014 | 08:07 AM
Vader's Avatar
Re: restoring 85 IROC
If the body is in good condition, it might be a candidate for a restoration. Is there something specifically wrong with the TPI unit or were you referring to the car in general?
Injectors can be cleaned and flow-matched, or they can be replaced outright. There are several places where injectors can be serviced, like Cruzin' Performance and others.
If you remove a rocker cover and find the casting number from the heads, that can be cross-referenced to original series casting numbers. Someone may have done you a favor by installing better heads, or maybe not. Without the casting number it is all speculation.
Also, there was no serialization of the head castings, only the block stamping on the RH deck extension, so no one will be able to read a number to determine whether the heads are original. The stamped numbers are here:
And the casting number is here:
Old Mar 15, 2014 | 08:17 AM
crewguy's Avatar
The inside of the throat is chalky and the butterflys are hard to push. I just want to make sure it's in good shape.
Old Mar 15, 2014 | 08:27 AM
crewguy's Avatar
gonna replace a fender (got a spare) and have it painted. The car even has the OEM floor mats!
Old Mar 15, 2014 | 08:38 AM
Harvey Mushman's Avatar
Car: 83 Z 28
Engine: LG4
Axle/Gears: dunno
85's a great year for the IROC BTW. Is isn't yellow is it?
Old Mar 15, 2014 | 10:05 PM
crewguy's Avatar
It's red
Old Mar 16, 2014 | 09:17 AM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
There is no point in putting money into the stock injectors(cleaning/refurbishing). These were not good injectors even when new especially compared to what is available now.
Southbay Fuel Injectors sell a superior replacement for a very reasonable price.
EDIT: I guess if you are looking to do a 100% factory/numbers matching resto, then having the correct injectors will be important. But if ultimately you are building a car you are going to drive and enjoy, an injector upgrade will make sense.
Old Mar 16, 2014 | 10:43 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
You should tell your son to stop drugging hoes and just pay them like the rest of us.
Pull the valve cover and see the casting number on the heads. Also if they are aluminum they are definitely not original.
Old Mar 16, 2014 | 10:51 AM
Joe Tag's Avatar
[quote=midias;5731395]You should tell your son to stop drugging hoes and just pay them like the rest of us.
LOL I so wanted to put a similar comment up, but I refrained. I figured it was coming sooner or later.
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
g.l.mos
Aug 22, 2015 12:02 AM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 11, 2015 03:17 PM
