throttle position sensor error...on a new sensor!!!
Old Apr 12, 2014 | 05:03 PM
Hlvo13's Avatar
Car: 1989 pontiac firebird formula
Engine: 5.7 350 tpi
Transmission: 700r4 i think
howdy all, I've been struggling with my 89 formula and its running ruff im getting the the throttle position sensor code and ive already put a new sensor in it. the sensor is putting out enough voltage so im at a loss any ideas, im starting to truly get desperate.
Old Apr 12, 2014 | 05:24 PM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Re: throttle position sensor error...on a new sensor!!!
Did you reset the ECM yet?
Old Apr 12, 2014 | 05:25 PM
Hlvo13's Avatar
Engine: 5.7 350 tpi
yah I disconnected the batter, reconnected it, then fired it up the second you turn it on that code pops up
Old Apr 13, 2014 | 01:46 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Hlvo13
im getting the the throttle position sensor code and ive already put a new sensor in it. ,
Which code ; high or low ?
Be aware
A code is for a fault SOMEWHERE in a system ;NOT that the sensor of that system is actually faulty.
You have to work through the fault diagnostics for that code ; could be a power , wiring or ground problem .
Which is why you identify the actual problem 1st before throwing $$$ at it in the hope it goes away
Old Apr 13, 2014 | 09:05 AM
Car: 88 IROC-Z
How long did you leave it unhooked for. It needs to be a unhooked for a few minutes to reset.
Old Apr 13, 2014 | 04:31 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Be aware
yeah ,like hey there might be something wrong .but were flintstone tech so .we really don't know. ok. enough with the "humor" EVERY PART of your TPS system needs to be looked at. twice. its the bane of our beloved 3rd gens . enough to drive you bat poo. I know but good luck
Old Apr 13, 2014 | 06:34 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
we really don't know. its the bane of our beloved 3rd gens
And the system diagnostics on the latest cars are no different.
They only indicate a problem seen in a system , with a flow chart on how to identify the problem
They don't tell you what is actually wrong and give you the part # needed to fix it
Old Apr 13, 2014 | 10:29 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
After you installed the new sensor did you bother to adjust it to specs with the throttle closed?
You only mention it's putting out voltage.
Old Apr 13, 2014 | 11:38 PM
Hlvo13's Avatar
Engine: 5.7 350 tpi
What do you mean?
Old Apr 14, 2014 | 12:01 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
What do you mean?
https://www.thirdgen.org/forums/tech...ml#post5747674
2nd post from the top.
Old Apr 14, 2014 | 10:50 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
The last couple of TPS' I have seen new are of the non-adjustable variety.
Old Apr 14, 2014 | 11:33 AM
Car: 88 IROC-Z
all you really need to do is "center it out" on the bolts.
(it needs to be straight up and down with no angle)
Old Apr 14, 2014 | 12:30 PM
Car: 86 IROC
Engine: 5.0 TPI
uh, no. you HAVE to adjust it for .5v at idle and the voltage should go up smoothly to near5v at WOT
Old Apr 14, 2014 | 05:07 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Really handy having newbies handing out potentially wrong advice
Need to state what year you are talking about ; not all are the same.
85 - 89 have to be set to a certain V value as stated above
90 - 92 are non adjustable and the ECM uses a different method to set the base value
Old Apr 14, 2014 | 05:23 PM
Car: 88 IROC-Z
New account, Iv been a member for 7-8 years and I know what im talking about.
88 IROC-Z
My car ran wrong and threw a code when it wasn't centered. But then again my car is a little "weird" from the factory...
Old Apr 14, 2014 | 05:41 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
This is correct.
Old Apr 14, 2014 | 06:02 PM
Hlvo13's Avatar
Engine: 5.7 350 tpi
I thought I had, it's an 89 tpi 5.7
Old Apr 14, 2014 | 10:09 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I know what im talking about...
I suspect ( actually I know ) if you read the TPS section in your FSM it will say different
The procedure is well documented on here and other online sources
https://www.thirdgen.org/tpimod2
http://www.iroczone.com/2009/10/adju...on-sensor-tps/
Old Apr 15, 2014 | 03:57 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
I had been having issues with my 305 tpi as well. it idles fine but a little gas ad it studders and pops. I switched out the tps for another one and adjusted it as it read in the articles provided above. No effect. I came across this thread and read that 90-92 are non adjustable. I have a 92 tpi. could this be why im still having the issue? I thought all tps were basically the same?
Old Apr 15, 2014 | 05:46 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by tonys91rs
I came across this thread and read that 90-92 are non adjustable. I thought all tps were basically the same?
They are but are setup differently
The '730 ECM used in the MAP cars uses whatever voltage it sees when the key is 1st turned on from the TPS as it's base value ; hence the non adjustable TPS on those engines
The MAF cars require the TPS to be set to the prescribed value
Old Apr 15, 2014 | 07:06 PM
tonys91rs's Avatar
Car: 91 Camaro RS
I need to switch back to a non adjustable tps in my car. I have the 730 ecm and map. what should the voltage be at turn on, or how do I test this type of tps to see if its correct or defective. im not getting any codes on it, before or now
Old Apr 15, 2014 | 08:42 PM
Car: 91 Trans Am
Engine: 355 TPI
It doesn't matter what voltage is at. The ecm uses whatever voltage its at on startup as its base reference. As long as the voltage goes up smoothly its good
Old Apr 16, 2014 | 01:41 PM
Hlvo13's Avatar
Engine: 5.7 350 tpi
i just remembered the first problem this car had was the engine coolant fan wouldn't shut off. it lead to the battery dying, then the ignition relay went out, then the fuel pump would randomly not work so I replaced that, and now its something in the throttle position sensor's loop. could any of this be related? could it be the manifold air temperature sensor? or the coolant temperature sensor? im only getting the tps code
Old Apr 16, 2014 | 02:42 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
What code is it?
Old Apr 16, 2014 | 03:21 PM
Hlvo13's Avatar
Engine: 5.7 350 tpi
Originally Posted by jazzdadss
What code is it?
43 I believe,
Old Apr 16, 2014 | 03:41 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
May need to double check, I show code 43 is for Electronic Spark control.
Old Apr 16, 2014 | 03:52 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
I show code 21 for TPS Voltage High and code 22 TPS Voltage low.
Mitchel 1 refers to it as a 5.7 PFI. Even though it is TPI.
Old Apr 16, 2014 | 04:18 PM
Hlvo13's Avatar
Engine: 5.7 350 tpi
I show that 43 can be tps, knock, or low voltage, but for the low voltage what should I do? also those small Bluetooth code readers worth anything? the like 20 dollar ones that you connect to a smart phone or laptop?
Old Apr 16, 2014 | 04:30 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
If you have a fax machine I can send you a flow chart?
Old Apr 16, 2014 | 04:51 PM
Hlvo13's Avatar
Engine: 5.7 350 tpi
I don't but can you scan it in and email it? that would be really helpful
Old Apr 16, 2014 | 04:52 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
I have no scanner sir. Sorry.
Old Apr 16, 2014 | 05:05 PM
Hlvo13's Avatar
Engine: 5.7 350 tpi
its fine maybe I can find it on google, what should I look for?
Old Apr 17, 2014 | 09:05 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
Pics from my phone.
Hope this helps.
Old Apr 17, 2014 | 09:12 AM
Hlvo13's Avatar
Engine: 5.7 350 tpi
thank you this should really come in handy
Old Apr 17, 2014 | 07:32 PM
Hlvo13's Avatar
Engine: 5.7 350 tpi
So quick update I got the new tps and dialed it in and the check engine light when off after I reset the car. It runs fine up until about 1800rpm then it misses like crazy and the tac jumps to 7000rpm. Then when it gets to about 2100rpm the tac drops to where it's supposed to be and the engine runs fine, I took off my distributor cap and there is buildup in it along with black carbon marks on the center also the rotor is pretty worn. The shaft itself is pretty rusty but turned alright. Could the cap be the issue? It is also running pretty rich from the smell
Old Apr 17, 2014 | 10:50 PM
TTOP350's Avatar
Sounds like you need a tuneup.
Old Apr 18, 2014 | 06:01 AM
Hlvo13's Avatar
Engine: 5.7 350 tpi
Yah I might aswell
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
someone972
Aug 30, 2015 12:52 AM
