Can TBI Engine Swap Into TPI GTA (considering a quick fix)
Old May 28, 2014 | 03:55 PM
Slowridr's Avatar
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
Want a cheap quick fix until I get an engine built and get other car from paint. May have a shot at free or almost free TBI.
Will a TBI motor go in my TPI car with no trouble, assuming I swap TPI stuff onto the TBI? Then I can cruise this car and not rush the painter on my other car.
What trouble awaits me if I pull the trigger on this? Any ECM issues? I will be pulling this engine out and putting a crate/rebuilt engine in next year so this is just a temp fix to a complicated situation.
Old May 28, 2014 | 06:07 PM
Chad85T/A's Avatar
Car: 85 T/A
Re: Can TBI Engine Swap Into TPI GTA (considering a quick fix)
It'll directly swap as long as they both have the center bolt heads. Since yours is a GTA and the said engine is TBI they both should. There should be any tuning issues with the swap since your keeping your TPI as long as the engines are the same CI.
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
