How reliable is GM TPI
Car: 1969 Camaro SS
Engine: 355, roller, Profilers, FIRST tpi
Transmission: 200r4
Haven't been here in a while mostly due to car being in paint jail. I plan on swapping a TPI onto my 350 doing a build like the GM HighTech Performance TPI 355 Something New, Something Old engine. Perfect for my street driven Camaro. I am gathering all the parts needed. I think a polished TPI unit is about the greatest looking induction system there is that is affordable.
My concern is this: how reliable is the GM TPI system? I look at all the threads in this forum and I read about fuel pressure problems, cold running problems, hot running problems, fuel pressure problems, and on and on. Is this just the result of old, oem sensors reaching their usable life and needing replacing? Is it a result of mismatched parts? Bad GM computers?
What are your thoughts on this? Thanks.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: How reliable is GM TPI
Car: 1969 Camaro SS
Transmission: 200r4
Well, that's interesting. However, it doesn't tell me why. I sure as don't know why I would want a Vortec Express van tune for a 400+ HP motor. I also have a built 200r4 so there won't be any parts swapping. Anything is fair game as far as the TPI goes. Again, I'll ask the question....how reliable is the GM TPI? Are the sensors a problem after so many years? The ECM?
Car: 88 Firebird Formula
Transmission: WC T5
Axle/Gears: 9 Bolt 3.45
The way I see it, the TPI might have been good and reliable back in the 80's. Don't get me wrong there are plenty still doing their job.
Now you can utilize newer technology into the older engines such as the 0411 PCM. I did the swap since I wanted to get the most out of my motor until the LS swap happens down the road.
Is the computer your using from circa 80 something..... Most likely not.
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
I had 200K miles on my Formula 350 TPI when I finally sold it. It still ran like a raped ape.
Transmission: T-5, TH350, T-5
I don't really think that's a fair question.
On this site you'll definitely see a ridiculous amount of owners seeking answers for problems on their TPI. Of course. A 20-30 year old system that could be hacked and damaged by PO's and possible shotty mechanics. Where are they going to go for advice? HERE.
Also mind you, the system(s) is one of the earliest EFI. All EFI from that era has repetitive problems from the industry figuring out what works, what doesn't. And wiring and parts do age. Maybe the good reason FAST355 suggested moving up......
Does that mean they aren't reliable in this day and age? Don't know. My TPI works flawlessly on 24 year old wiring. And so do many others. But how often do people ask questions if their car is running too good?
So does that answer the question. I don't think so. Not a fair question.
Engine: 4++,350 & 305 CIs
A lot of problems come from owners that "fix things" without a problem being there or not really knowing what they are doing.
Yes, these cars are old and the older they get, old and even new problems pop up.
I daily drove mine for years an yrs an put hundreds of thousands of miles on mine.
Even drive it half way across the country at 240,000 miles and she hasn't ever left me stranded.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
As already observed ;
use some 25 yo hacked up harness and a original sensor from 1985 then you are asking for problems
this forum is full of threads "
I bought this 25 yo POS car that hasn't been maintained in 20 years , was butchered by 10 shade tree PO's and I can't get it to run properly
therefore TPI is CR*P
Car: 1969 Camaro SS
Transmission: 200r4
Use a new wiring harness and sensors and it is as reliable as back in the day when '000's came off the production line in the '80's
As to aliceempire, sorry it was and is a fair question. Its very simple, will a brand new TPI system be reliable? No different than "can I get theis much hp if I do this and that". Fast355 decided not to answer the question.
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
In my experience TPI engines are actually pretty reliable, especially if you replace the normal parts(injectors, fuel pump, etc) that cause issues when they are 20+ years old. But TPI is outdated 80s technology..the ls stuff or aftermarket efi setups are much better especially in tuning and diagnosing when you have a problem.
Car: 1983 G20 Chevy
Transmission: 4L60
That is what I figured. Fresh wiring with fresh insulation and connections, new sensors and most of the problems I have read about go away. I am intrigued about the 0411 ECM as I need to get a ECM.
My thought behind the 0411 is just the fact it uses a much more modern processor, offers sequential fuel injection and rather than burning chips you can simply flash the PCM to make changes with HP Tuners. Almost no tuning shops mess with OBD1 TPI. EVERYBODY tunes LS1s.
Car: 1969 Camaro SS
Transmission: 200r4
Actually, I just sat down after getting off work and mowing my yard. Not that I didn't want to answer your question, just got occupied with this thing called work.
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
TPI is reliable as it was brand new. The problem is that when a lot of these young guys by these cars, the first thing they want to do is start removing parts to clean up the engine bay. They can't just leave stuff alone. Then they start hacking up wires trying to get the fans to come on when they want it to not knowing that you can change the sensor in the passenger head to come on at 185*(2nd fan), and the primary fan can be change in the chip to come on sooner. These are just some of the problems why stuff gets screwed up. In short they don't know what their doing.
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
The 411 ECM is from an LS1. Therefore you want an LS1 harness. The connectors will mostly match the sensors; such as injectors, TPS, IAC. Some of the sensors may need to be from the LS1 ... knock? then add crank & cam position sensors. You end up with electronics from the LS1 connected to your SBC with TPI intake manifold.
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Don't forget that for the 0411 ECM you will have to buy an expensive ($500-$900) programming package to program the 0411 ECM to go along with the LS1 style harness. You will also need a Vortec style distributor and coil, and a Crank Position Sensor and associated drive gear for the crank, along with a new timing chain cover. Forgot to mention that it won't work with a 200-4r/700r4 without special speed sensor adapters. Works easier with a 4l60 or newer trans.
I really wanted to do this swap on mine,but the cost of the programmer put it over the top of my budget ( since I had already replaced everything with new anyway).
As for the reliability, I concur with the others that it can be a very reliable package. Many here have over 200K miles. I did the swap a few years ago, and replaced all the sensors ( to ease installation issues). I've had no issues at all.
The only sensors that really go be are the O2 sensor and the MAF. Other than that the others still works after almost 30years. The hackers screws up the rest of them.
For peace of mind and easier troubleshooting, I would consider replacing the stock injectors with re-manufactured Bosch III's, and rebuild/replace the Fuel Pressure Regulator. Check the EGR and temp sensor and replace if in doubt. All of these are under the plenum, and are much harder to fix after the fact. This also goes for the Air Temp sender in the plenum.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
To answer the man's question. Yes, Tuned Port Injection is reliable. I just drove from Arizona to Connecticut in the middle of summer, it was an amazing trip.
Get to know the system, keep it cool.. Do preventative maintenance and she wont let you down.
Car: 1969 Camaro SS
Transmission: 200r4
Yes. In reading more about the 0411 pcm, total overkill for what I want to do. I am not interested in coil overs, crank trigger timing, etc. Will either megasquirt it or go GM ECM and reprogram.
I've looked into the 411 pcm and all that goes with it, and there's no doubt it's an awesome upgrade. That being said, my main reason for wanting to do it was the availability of tuners. Either for my current plans or anything I may do in the future. My current L98/zz4 cam runs on the stock 89 hardware and runs AWESOME! No trouble with the sensors, the engine, the computer, or the tune. It runs really good on the stock "chip", and it runs a little bit better, albeit not much, on the PCM for less "chip".
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 88GTA
Engine: 5.7TPI
And on and on. I was waiting to chime in but didn't want to be a ****!
Sorry if I offended anyone on here, but I see it allot
ToolGuru....Had my 88 since new, 193k miles. Keep it tuned and maintained and it runs like brand new. To each his/her own though
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
My TPI has been pretty awesome, one of the best aspects of the car IMO.. Ofcourse, I have invested in new sensors, blocking off AIR, EGR, 9th injector and ofcourse did some tuning to make it perform better and work with the physical changes I've made.
BTW, I had a code 36 that suggested MAF Burnoff Diagnostic was faulty or wtv.. I ended up taking apart intake tract, cleaning filters, cleaning intake tract, cleaning MAF screens, blowing pressurized AIR in the MAF sensor (there was crud everywhere inside and out) and cleaned inside throttle body and the code went away. Some people suggested getting a new MAF which solved their problem, but maybe the problem was just that it needed to be cleaned, well, for me that was the issue. Point being, sometimes on forums people complain and maybe just change the whole part but it was not actually required to spend that money in the first place.
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
ToolGuru, I think the TPI system is fairly reliable. Start with a good wiring harness, replace all the sensors and relays and get a GM shop manual. Know the limitations. The early MAF systems can accept cam and head changes up to a point without having to change the ECM programming. When I did the TPI swap on my 87 Monte Carlo SS, I kept on the conservative side. I've been running it for about 2 years now without any major problems. Knock on wood! The first problem I had when I did the swap was the motor would not start. Eventually I re-checked my ECM pin-out and compared to the shop manual. I forgot to insert a pin in the harness for the VATS signal, dumb mistake. The other problem I had was a weird idling issue. Discovered the wires to the IAC were mixed up. Fixed that and been fine since.
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Pretty much dead reliable.
GTA bought at 19k miles, 67k on it now.
91 Formula bought at 40k, 122k on it now.
In stock incarnations and a lot of miles on each I lost an alternator at 80k on the Formula, fuel pump at 90k or so.
GTA lost the injectors in the low 20k range. GM injectors used on TPI(and some others) were known to fail however so not unexpected.
I have come to the conclusion using the 0411 on older small blocks is a waste of time and money unless u possess the skills to do it yourself(which I could). If your going to buy it all to plug in play you might as well hunt down a LSx swap for that kind of money. If you do it yourself junkyard style, it would be a nice upgrade.
IF you have a good harness or a new harness for TPI this is your best option out there:
http://www.dynamicefi.com/
Nice setup, stock based along with self tuning.
Learn about how TPI works, understand the system and get it running 100% before attempting any mods goes a long way to solving a ton of issues.
Car: 88 GTA Notchback
Axle/Gears: don't know
The thing i like about TPI is what I tell a lot of people, "Easy enough to work on at home, complex enough to make you look good". No special tools except a Laptop and cable required.
I have a good story about my experience with TPI. Got off of work, and the fuel pump died. Was able to start it and drive it home (albeit maintaining no less than 2500 RPMs at all times) for almost 15 miles. Burned up all the spark plugs and cooked the injectors, BUT it did get me home. Try doing that on a "modern" system. There is a reason why the SBC was left pretty much unchanged for 40+ years.
Yes, the haters will hate. But, if you don't f- with it, and just MAINTAIN it, it is just as reliable, if not more, than any other system out there.
I can attest to this. Change out for new sensors (which are pretty cheap btw) and if it hasn't been all hacked up or messed up by a previous owner, then it's damn reliable. Never had an issue with TPI really (the MAF TPI systems also do very well at compensating for cam/heads upgrades).
Car: 1983 G20 Chevy
Transmission: 4L60
I don't remember the website, but I picked up a 6" piece of Chrysler rated submersible fuel hose for something like $3. Works just as good as the expensive stuff.
Sanjay
Aug 12, 2015 03:41 PM
