L98 running lean
Old Jul 6, 2014 | 07:31 PM
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
L98 running lean
I've got a problem I've been trying to work out with my car. After I added my intake mods it started running lean and hot all the time and I can't pass smog with it. The NOx value is too high, all the other measured particulates are well under the allowable limits.
I've got an '88 IROC with an L98 with full bolt ons on the intake and exhaust side. I made a ram air set up, 52 mm throttle body, ported plenum, ported SLP intake runners, ported edelbrock base. On the exhaust I've got 1 5/8'' Hooker headers, hooker 3'' y-pipe, and a flowmaster 3'' cat back exhaust.
The head and cam are stock L98. I haven't changed those yet. I'm still running the stock computer, stock chip and 22 lb/hr injectors.
I set the timing to the factory spec 6 degrees BTDC. I've also got new MSD plug wires, plugs, cap and rotor.
It stays above 240 degrees as well. I've also got a new water pump and new stock radiator as well. What should I do to have it not run lean? Get larger 24 lb/hr injectors and a tune? Or could something else be the problem?
Old Jul 6, 2014 | 08:29 PM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Re: L98 running lean
(subbed)
Old Jul 6, 2014 | 11:23 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
How do you know it's running lean?...are you basing it off smog reading/then internet search?
Suggest a monitoring tool and look at the O2 sensor voltage to start.
Old Jul 7, 2014 | 09:48 AM
yaj15's Avatar
Car: 1988 IROC-Z
Smog results and the O2 readings from a live time digital tuner. I'll re-check the 02 sensor voltage as well. What should it be reading?
Old Jul 7, 2014 | 11:03 AM
Car: 88 IROC-Z
check the ING. timing, it could be to far advanced.
Old Jul 7, 2014 | 11:05 AM
yaj15's Avatar
Car: 1988 IROC-Z
I'll re-check the timing as well and make sure it's still at 6 degrees BTDC.
Old Jul 7, 2014 | 04:28 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
High NOx readings is a common issue with even stock engines in CA. Please scan or post your test readings for all 5 gases. This could help with a diagnosis.
I'm assuming you pass visual in that all smog equipment is still present (like the AIR pump)?
Check for vacuum leaks (including the HVAC system) which can cause a lean condition.
Has the EGR system been looked at? If you have an FSM, go through the functional test flow chart that's in the FSM to confirm.
Dirty combustion chambers can make the chambers run hot. Maybe run some Seafoam through the intake.
How old is the cat?
Is the ECM staying in closed loop under test conditions?
Take a look at your 2012 emission test results as see if the state didn't up the passing limits for 2014. This won't help you much but I've noticed this on test limits for my other cars.
There was another CA member here that burned a chip with the just the timing advance table "locked" at 10-degrees and got his car to pass.
Edit: FWIW, Here's the thread regarding the timing table:
https://www.thirdgen.org/forums/tpi/...g-3rd-try.html
Old Jul 7, 2014 | 04:41 PM
yaj15's Avatar
Car: 1988 IROC-Z
How old is the cat?
Thanks for the tips. I live in Modesto so I'm not that far from Tracy. Yeah these stupid smog laws!
Yes I passed everything else for the visual and actual text results except for the high NOx values. Tuning is going to be part of what I have to do as well. I just wish it wouldn't run so hot, maybe the NOx wouldn't be so high and I could pass the test.
I've gone through the EGR system, replaced the valve, the switch, etc.
It goes into closed loop, I've had it on a live time tuner a couple of times.
Vacuum leaks and running seafoam are the next things I'll look for besides a chip and adding bigger injectors.
I had a new cat installed late last year (October-November) and I haven't driven my car 1,000 miles since it got installed so hopefully the cat didn't crap out that fast.
Old Jul 7, 2014 | 05:42 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Did it fail at both speeds on the dyno?
Old Jul 7, 2014 | 05:44 PM
yaj15's Avatar
Car: 1988 IROC-Z
Yes at both speeds on the dyno the NOx was too high.
Old Jul 7, 2014 | 06:19 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Well you're close enough to me, you're welcome to come over and plug in my Scan tool and see what the ECM is seeing.
I don't recall how to log the data with it, but still have the manuals,,,it's a SnapOn MT2500.
PM me for contact info if you'd like.
Old Jul 7, 2014 | 09:09 PM
yaj15's Avatar
Car: 1988 IROC-Z
Thanks. I'll try some other things first and see if I can get it to work.
Old Jul 7, 2014 | 09:27 PM
yaj15's Avatar
Car: 1988 IROC-Z
These were the smog results from the last test:
15 mph test: 1,398 rpm
%CO2: measured = 13.5
%O2: measured: 1.8
HC (PPM): measured = 13, average = 48, max = 83
CO (%): measured = 0.00, average = 0.12, max = 0.71
NOx (PPM): measured = 1814, average = 227, max = 537
25 mph test: 1,345 rpm
%CO2: measured = 13.4
%O2: measured: 1.9
HC (PPM): measured = 9, average = 35, max = 83
CO (%): measured = 0.00, average = 0.09, max = 0.40
NOx (PPM): measured = 1645, average = 202, max = 494
Old Aug 28, 2014 | 09:51 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Did you ever sort out your problem?
Old Aug 29, 2014 | 09:38 AM
yaj15's Avatar
Car: 1988 IROC-Z
Not all together. I'm still working on it. I got a Summit Racing aluminum radiator. That took care of the over heating issues. The high operating temperatures was why it was running lean. Now I'm going through the ignition system. The car has a miss in it now and I'm trying to figure out where thats coming from. After that I'll see how it runs and try to smog it.
Old Aug 29, 2014 | 05:24 PM
What made you suspect the stock style radiator was a problem even though it was new? What radiator did you go with?
Old Aug 29, 2014 | 05:31 PM
yaj15's Avatar
Car: 1988 IROC-Z
Even after I installed the new stock radiator, my car was still running hot - over 240 degrees.
I got a summit aluminum 2-row radiator and it never gets higher than 220 degrees now. The additional coolant capacity the radiator has helps too. I had to have a friend of mine make custom mounts so it would fit. I keep the stock factory dual cooling fans as well.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
