Oil Pressure Sending Unit Install
Old Jul 23, 2014 | 01:20 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
So, I purchased a new oil pressure sending unit and snapped off the metal electrical connector with the hole in it while installing it. There's just no room to work back there to install it properly without bending that metal piece. I'm going to buy a new one, but was wondering if there is a trick to installing this back there? I bought a ratcheting wrench set which should help save time and back pain, but that won't help the metal connector always breaking.. Hmmm.. Thoughts? Thanks
Old Jul 23, 2014 | 02:20 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Oil Pressure Sending Unit Install
There is a black cover over the sender that pops off. Try to reach the nut with a deep socket. I bought the oil sender unit socket kit. The first time I removed my old one with the black cover on, so I figured, it would go on the same. Well, the socket wouldn't set completely on the sender and I kept twisting the socket off. Then I told a friend it's just not working, he grabs the old unit and pops the black cover off and goes, "Hmm, the socket is definitely long enough". Lol. I cried inside and went back to the new unit, popped the cover off, put the sender socket on and it was super easy from there.
Old Aug 7, 2014 | 02:10 PM
I'm not sure I'm following. The unit I purchased does not have a black cover on it (or any cover?) It looks as such (see attached image).
The metal connector with the small hole in it at the tip is what brakes off from the whole unit when I try to install it because the only way to line up the whole unit to thread it into the back of the engine is to bend this metal connector slightly and then when it's threaded it I bend it back into place, but it broke on me. So I'm stumped at how to thread this in to the engine unless that metal connector somehow comes apart or something? Not sure..
Old Aug 7, 2014 | 02:20 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Is the elbow in the top of block pointing to the drivers fender? Thats how mine is oriented. Then I used a open end wrench.
Old Aug 7, 2014 | 03:09 PM
Mine was facing sort of towards the back of the car, towards the firewall, but off to the driver's side. So there's that part of the firewall sticking out and in the way lol. That piece back there is move-able but it doesn't go as far as facing the driver's side fender.
Old Aug 7, 2014 | 03:16 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
You could remove the elbow and re-tape and turn it back in. You said that it is movable, so it's probably loose and needs taped any way. Then tighten it up to the point where you can get the unit screwed in. Unless the elbow hits the intake while trying to back it out, then that won't work.
Old Aug 7, 2014 | 03:27 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Carefully Bend It Here Before You Install It,I Recently Replaced Mine And The Original Factory Unit Was Bent. Just No Room To Install It Straight On.
Old Aug 8, 2014 | 09:55 AM
Looks like I'll try round #2 and not snap it off this time lol
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Irocohio
Aug 12, 2015 08:03 AM
