Fuel system troubleshooting tips.
Old Jul 25, 2014 | 01:40 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Engine: 90-95 ZZ4 Crate 350 TPI
Transmission: 700R4 4spd Automatic
Axle/Gears: 3:73
1986 305 TPI Fuel system
Last Sunday I planned on going to a car show down in Midvale UT. (80mi round trip) Tanked her up and thought it was time to put in some FIC (fuel Injector System Cleaner). Started the journey and about mid-way, I get a service engine soon light. Performance didn't change, checked my gauges and checked engine RPM and acceleration...all were nominal. On the way back, it came on again. When I spun her around and backed her into the garage I got a nasty raw fuel smell in the compartment. What do you think it could be? I have another car show on Saturday...need some quick trouble shooting tips...
Thanks!!!
Old Jul 25, 2014 | 02:51 PM
mcquigg's Avatar
Car: 85 T/A
Axle/Gears: BW Limited Slip 3.27 w/disc brakes
Re: Fuel system troubleshooting tips.
You need to narrow down where the fuel odor is coming from, rear of the car or from under the hood.
Old Jul 25, 2014 | 03:47 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
okay. I will start her up and see what's up and reply pretty quick I hope.
Old Jul 25, 2014 | 04:11 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
After start up, it smelt a bit like raw gas at the rear of the car, but cleared up.
Let the motor get out of open loop and get up to temp. Felt each injector and all were pulsing, except for the back two injectors on the right side. they were faint.
Could the fuel be pooling up in the fuel rail? Went back and took a wiff of the exhaust smells a bit rich.
Also, I had the TPI off last fall to sand and buff the TPI Head. Put everything back on as advertised. should I have checked and re-torqued the TPI Runners after a certain amount of mileage? Just throwing that out.
Old Jul 26, 2014 | 09:50 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
well, first, check your codes. that will take a lot of guessing out of the mix. if you have the stock factory injectors.it could be time for a set of bosch3s from "southbay".
Old Jul 26, 2014 | 10:18 AM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
Okay, now I went to south bay injectors. what would be the stock injector PSIG? I saw 19PSIG will that work if I need the injectors? Also If I may ask, do you know whether or not GM put a factory in-line fuel filter anywhere? I remember when I changed the pump in 2001, it simply had a strainer pouch on the bottom of the pump assy. Tried to get the codes read at O'Reilly's with a OBD-1 reader and nothing pulled up. Course the service engine soon light wasn't on. That's the other wild thing, when I take the car around in the city the light doesn't come on...the darn thing comes on when I am at freeway speeds.
Old Jul 26, 2014 | 11:28 AM
Car: 86 IROC
Engine: 5.0 TPI
the factory fuel filter is located under the left side of the car just behind the drivers seat area. but ahead of the left rear wheel. and a 305 takes 19lb .hr injectors. you can read the codes yourself with a bent paper clip.looking at the ALDL terminal its the top right hand two connections. and there IS a code. anytime the CEL comes on a code is set. good luck ,and let us know how it goes
Old Jul 26, 2014 | 01:01 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
I want to thank all of you guys for your help. I really love my car and want her back on the road so I can let everyone know that third gens do exist and we're not going away.
Old Jul 26, 2014 | 01:25 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
Really? Really? Not too funny...(jeff880)
Old Jul 27, 2014 | 03:53 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
Got it. is there a table listed for the codes and their meanings???
Old Jul 28, 2014 | 09:20 AM
Car: 86 IROC
Engine: 5.0 TPI
you can post the codes here and we will tell you what they mean,deal?
Old Jul 28, 2014 | 05:49 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
http://innova.com/en-US/Product/Deta...4-6b58267cde57
I bought one of these at Wal-Mart for about $20. I just leave it underneath the seat for those rare times when you need to scan for codes while out on the road. Comes with a book that tells you what every code means.
Old Aug 3, 2014 | 06:54 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
Old Aug 4, 2014 | 05:03 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
Code read EGR Valve. Changed the in-line fuel filter just for safety sake.
- Fuel Pressure read 35@idle and 45@ increased RPM's. No leaking from the fuel pressure regulator so that's a good thing. So fuel isn't a issue.
- I am going to let her cool down and then commence to taking of the TPI again (took it off about 6 months ago to polish the plenum.
-- I am thinking about just taking out the T-40 bolts that attach the runners, disconnect the throttle bracket and ease it out of there. Hopefully, the gaskets should stay put, don't you think?
-- EGR valve has to come from out of state, so I have a few days to take my time and do this right.
- Now, before I simply buy the EGR Valve, should be safe and replace the EGR solenoid as well?
-- I was also thinking about changing out the Fuel evaporator filter (in canister) as well...maybe it's dirty. could be the smell I got. Any other factors I should be aware of before I start this process?
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Grant2k
Jul 10, 2018 04:01 PM
Fast355
Dec 2, 2016 06:33 PM
beachrodder
Aug 25, 2015 08:05 AM
