87 305 tpi stalling issues
Old Aug 3, 2014 | 06:52 PM
BftCamaro's Avatar
Car: 1987 camaro Z28
Engine: 5.0 TPI LB9
Transmission: 700r4 auto
Axle/Gears: 2.62:1
Guys I really need help ..... My car wont idle .....if i try to start it I won't start or it will start and stall ....but if I disconnect the maf it won't start the first time but if try to start it again it will run and idle at about 1500 and took it for a drive It had a really slow take off and sounded like it wanted to die once it down to 800rpm ...I got a new maf which costed 215 but it didn't work so I returned it ...someone please point me in the right direction
Old Aug 3, 2014 | 09:36 PM
BHicks's Avatar
Car: 1986 Monte Carlo SS Aerocoupe
Engine: L69 305 H.O.
Transmission: 200-4R
Re: 87 305 tpi stalling issues
Throwing any codes?
Old Aug 4, 2014 | 04:56 PM
BftCamaro's Avatar
Engine: 5.0 TPI LB9
Axle/Gears: 2.62:1
I have no way of checking them
Old Aug 4, 2014 | 06:32 PM
BHicks's Avatar
Is the Service Engine Soon light on?
Its easy to pull the codes all ya need is a paperclip.
I dont live far from ya be glad to help all i can if you need.
Old Aug 4, 2014 | 08:28 PM
racerx520's Avatar
when you disconnect the MAF it should throw a code, when it does that, it goes into a "default" mode where the engine runs with dumping fuel in, running a higher idle and has no regard for emissions (which is really the only reason for the computer in these era cars) so it just does what it needs to in order to run.
what made you want to disconnect the MAF in the first place?
Old Aug 4, 2014 | 09:12 PM
BftCamaro's Avatar
Engine: 5.0 TPI LB9
Axle/Gears: 2.62:1
Check engine light is not on and I currently stay in orrangeburg sc
Old Aug 4, 2014 | 09:17 PM
BftCamaro's Avatar
Engine: 5.0 TPI LB9
Axle/Gears: 2.62:1
We'll when I disconnect it it will run .....but when I drive it while it's disconnected once the rims get around 800 like if I'm coming to a stop or something it will try to stall out.....and the reason why I disconnected the maf is cause a mechanic friend of mine told me to try it and when the engine started and ran we assumed that was the issue but...we were very wrong
Old Aug 4, 2014 | 09:31 PM
BHicks's Avatar
It should throw a check engine light with the maf unplugged as stated. You can guess and throw parts on it all day to no avail.
On my car I had a maf code, bought one from amazon , put it on and no difference. Went and got one from ac delco and it purrs like a kitten. But it should throw a code if maf related.
Does the check engine light work and not burnt out? It should come on with the key in the on position.
Old Aug 4, 2014 | 09:36 PM
BftCamaro's Avatar
Engine: 5.0 TPI LB9
Axle/Gears: 2.62:1
Now that you say that it might be burnt out I can't recall at the moment but the maf I dId buy was a Bosch
Old Aug 4, 2014 | 09:45 PM
BHicks's Avatar
Yea, I don't recall exactly what brand the first maf I bought was. But they can be bad even out of the box. I knew my original was junk because I could see the filament was broken inside it.
First thing I suggest would be check to see if that light is operational. If not put a bulb in it and check for ECM codes. These sensors on these tpi engines will give you fits as I'm sure you know. No need in wasting money and time guessing. A lot of good write ups here and people willing to help but gotta have a place to start first.
gta90
Sep 15, 2015 04:00 PM
Jae992
Aug 27, 2015 09:07 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
