MSD multi spark box?
Old Aug 13, 2014 | 06:46 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
im considering buying a MSD multi spark box for my TPI car. a 6 AL or something. im considering it mainly for the increase in MPGs that it might offer. I would like to hear from other members who have used this on a otherwise stock car. how did it do? were there other parts that had to be bought to realize its potential? did you get any better MPGs?:
Old Aug 15, 2014 | 11:26 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: MSD multi spark box?
Nope waste of money.
Good tune clean fuel filter proper tire pressure etc and hope for the best.
MSD are not magic
If you have a power adder forced induction or a large by huge cam there can be a small benefit..I use one due to a cam with 81 deg overlap...and a rev limiter. One day it will let me down lol.
HEI and a good coil cant beat it for reliability.
Old Aug 15, 2014 | 11:40 AM
ThirdGenKen's Avatar
Car: 1987 Chevrolet Camaro Iroc Z28
Engine: 383 Stroker supercharged.
Transmission: 5 speed manual transmission
Axle/Gears: 3.45 posi rear
I have a full MSD ignition in mine and I like it. I think it's worth it. Just my personal opinion though.
Old Aug 15, 2014 | 06:47 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I have one on my TPI and one on my L31 Vortec engine. BOTH are worth it to me. Adding the MSD along with a slightly wider plug gap gave me a smoother idle in both and a noticeable increase in both low-end torque and throttle response. In both applications I was able to remove some fuel out of the VE/MAF tables due to a more complete burn.
Old Aug 15, 2014 | 08:22 PM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Iv hit the rev limiter in my box a bunch of times-
part# 8xxx BIG blaster TPI coil is worth it on its own too
Old Aug 15, 2014 | 09:01 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
I looked into this as well. The consensus seems to be that if it's a daily driver and/or you mount it under the hood, that the reliability of them is pretty bad. Numerous people report having them die within a year. Mounting them under the dashboard or under the seats removes the high heat aspect and prolongs life. Not being a daily driver helps too.
Mileage gain? Anywhere from 0 to 2 mpg.
I ultimately replaced everything ignition wise, but did not buy an MSD. Just went for a stock AC Delco coil and MSD cap/rotor. MSD plug wires, AC Delco sparkplugs.
Old Aug 15, 2014 | 09:21 PM
Car: 86 IROC
Engine: 5.0 TPI
seems kinda puny to me. the only good place to mount it IS under the hood! but thanks guys. looks like ill just keep it stock. not worth the hassle for one year and over 3 bills at that.
Old Aug 31, 2014 | 03:56 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
I've had my MSD-6AL in my daily driver IROC for about 10 yrs now, mounted under the hood, never had a problem, it's been rock-solid reliable. I also used the (optional) MSD 8876 wiring harness that adapts it to the factory dual-connector coil, made the installation wiring super-simple. yeah, you still have to crawl under the car and hook up the hot wire at the starter.
'90 IROC 5.7L TPI
Old Aug 31, 2014 | 07:26 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
PepBoys has a 25% off online orders sale that ends today...
Pep25 is the code
I paid $179 form y MSD 6AL with Rev limiter 6425 (newer design, digital)
And about $35 for my 8226 GM Coil...
Out the door with tax $229, normally the MSD box itself is $239
I applied for a $25 rebate from MSD they are running through September, then I went to Square Trade and used a 40% off coupon for a 3 year warranty on the MSD Box too...
With Warranty minus Rebate, $232
I had a Digital 6 and coil before and it smoothed out the idle had plenty of power at high rpm...
Old Aug 31, 2014 | 12:02 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Not worth the money on a stock car.There quality has gone down over the years.Had one a couple years back,it lasted 6 months.Tried the new digital Crane box. Again that one lasted about 6 months.A part that says made in America only has to have 75% of the parts actually made in America to be considered made in America.That's the law.
Old Aug 31, 2014 | 02:19 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
remember..GM also had MSD make boxes for them..and they do work... this is just 1. of many diff ones..
this one on ebay is still under $120 for the nexed few hrs
good deal...
GM did alot of biss with MSD.. and they still do..
Old Aug 31, 2014 | 04:03 PM
Car: 88 IROC-Z
Iv got the digital box, the plug n play harness and the BIG coil. Ha all three for like a year or more, still going strong.
Old Aug 31, 2014 | 06:27 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I have the complete opposite opinon, I wouldn't drive a distributor equipped vehicle that did not have some kind of hotter than stock spark setup.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Jlanz55
Sep 9, 2015 09:09 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
