running rich 350 to 383 tpi swap
Old Aug 17, 2014 | 07:36 PM
drdpr72's Avatar
Car: 89 iroc
Engine: 383 tpi
Transmission: t5
Axle/Gears: 327 9bolt
89 5.7 tpi to mild 383 tpi lots of bolt ons vehicle seems to be running very rich plugs black/damp exhaust is white smoke on start smells rick popping in exhaust 02 reading stuck on rich mat and coolant temps seem to be ok unplugged maf sensor vehicle died instant started a few times until it ran with maf disconnected then plugged it back in seem to run much better live data shows o2 lean to rich at this point then when to check timing disconnected adv wire car went to rich on data log even after adjustments made and wire plugged in will not come back off rich? lost not sure where to go at this point very new at tpi but testing everything I can think off btw factory ecu with hypertec prom I don't have any stock proms to compare running? please help
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
st.evel07
Aug 13, 2015 06:15 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
squiggy2
Aug 9, 2015 09:30 PM
