FFS, what could I have done installing my runners and plenum?
Car: 89 IrocZ
Engine: L98-ish
So, last weekend, installed new injectors...and a bout with my FP gauge, cycled the pressure several times, all holding and no leaks at all.
Got my gaskets in today, bolted the runners and plenum in...went to fire off the car (good thing battery was low and didn't have enough juise to spin it over) and heard a hissing sound.
Went to get the charger, came back and smelled fuel.
Yep...intake manifold on the left side, had puddles of fuel in it.
Had my daughter cycle the key, sure enough #7 injectors spraying fuel out from the top under the fuel rail.
So, it held pressure and didn't leak a drop, until I bolted up everything else...ya, will figure it out later tonight, or in the morning, but looking for "been there, had it happen to me too" replies...sure an Oring can't go to hell from sitting for a few days, so that would lead me to a damaged injector, but how?
Open to all thoughts, comments and yes..."ya dumb chit, this is what you did" comments/replies.
Grrr, getting too old for this stuff
COTM Editor (Retired)
Car: 89 Formula 350, TTA
Re: FFS, what could I have done installing my runners and plenum?
Did you have to loosen any of the four fuel rail bolts in order to install the runners, and then maybe forgot to re-tighten them?
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Which injectors did you use, stock or Bosch 3's? Stock injectors are installed into the fuel rail first then the assembly is installed into the manifold. When I bought my Bosch 3's from South Bay, if my memory serves me correctly, their instructions were clear that you must install the injectors into the manifold first then install the fuel rail.
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
If it leaks from the top between the fuel rail and the injector, make sure that you locked the injector in place and the oring is not cut. Try to spin the injector back and forth to help seat the oring in the rail before you take anything out.
I doubt this, but did the old oring stay inside the rail before you put the new injector in?
Car: 89 IrocZ
Engine: L98-ish
The orings were lubed prior to install, put them in the intake first (SB's Bosch 3's).
Dididn't have to loosen any thing to get the runners in place
No orings left in the rails, didn't think of spinning it before pulling the runners again last night-doh..
But what has me scratching my head is they held fine a few days ago when I tested them, (waiting for my gaskets to come in), only difference is putting the runners/etc on yesterday.
Didn't pull the rail yet, was getting too late, will try spinning the leaking one see if it helps.
Saving grace is it was a good thing the battery needed a charge, otherwise you guys would probably be posting links of my burned down garage and car
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Car: 89 IrocZ
Engine: L98-ish
Lol, building up the energy to head out back...need a few more cups of coffee, and let the Geritol kick in...
Car: 88GTA
Engine: 5.7TPI
Car: 87 Camaro Z28
Engine: TPI 350 bored .030 over
Yeah I've nicked a few orings tinkering with different injectors. It's very easy to do if you don't pay close attention and never try to force them. I try twisting gently on each injector as I'm pushing down the fuel rail. They'll usually just slide easily into place that way.
Car: 89 IrocZ
Engine: L98-ish
Car: 86 IROC
Engine: 5.0 TPI
Car: 86 IROC
Engine: 5.0 TPI
Car: 88GTA
Engine: 5.7TPI
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
I'm 55, maybe we should start a old guys thread. Lol Seems like maybe we have forgotten more than we remember. I had removed my fuel rails once and thought i had them tightened only to find out while the car was running that i forgot to tighten them. I had fuel spraying everywhere. lesson learned.
Car: 86 IROC
Engine: 5.0 TPI
Car: 88GTA
Engine: 5.7TPI
Case in point: Got my chip back from Brian @Tuned, grabbed the wife and fired up the car with the hood up....purred like a kitten.......till I reved it up to check it out........all of a sudden spray and steam EVERYWHERE! I thought I blew it up! Nope, Just forgot to tighten that clamp on the heater hose that she asked about 5 minutes earlier!
Car: 89 IrocZ
Engine: L98-ish
I use the "CRS" syndrome, can't remember shlitz
Well, she's alive and kicking now.
That's the first time in 3 or 4 years since it ran, need to put the muffler on, weld the tips up, then save up for some tires...only a few thousand miles on them, but 15 years old and dry rotting.
Might call the Ex over before swapping tires, see if she wants to do any high speed runs for old times sake
Car: 88GTA
Engine: 5.7TPI
Car: 89 IrocZ
Engine: L98-ish
Car: 1987 iroc
Thats what we need is some humor once in a while. Glad you got it running. Thread
mdtoren
Aug 16, 2015 05:45 PM
