88 tpi dies when warm
Old Jan 2, 2015 | 07:55 AM
jamiepz's Avatar
Needing some help with 88 GTA 5.7. Car fires up good when cold but begins to surge and dies soon after begins to warm up. Fuel press good and no ses light. Need some advice on what to check.
Appreciate any info
Thanks Jamie
Old Jan 4, 2015 | 06:50 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: 88 tpi dies when warm
Coolant temp sensor circuit, o2 sensor circuit, and vacuum leaks when it's warm (loose plenum bolts etc.)
Old Jan 4, 2015 | 08:37 PM
jamiepz's Avatar
Thanks for your reply. I'll see if I can check those things. When it dies it is immediate and clean like turning off key. The injector wires stay hot when it happens as do the pink and white wires on coil, however according to my test light, both the white wires loose circuit when it cuts out but maintain power. Thanks in advance for any more help.
Jamie
Andrew6.688
Dec 13, 2015 10:59 AM
Wade787b
Sep 29, 2015 01:15 PM
bamaboy0323
Sep 3, 2015 06:07 AM
EFR2000
Aug 18, 2015 08:54 PM
Sanjay
Aug 12, 2015 03:41 PM
