90 5.7 runs rough no power and no combustion on pass side help me solve I'll paypal $
Old Jan 3, 2015 | 07:50 PM
j88l98irocz's Avatar
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
Hey guys, I have no combustion on pass side car runs like crap, no power noticible miss ect If I put my laser thermometer on exhaust ports 2-4-6-8 they're cold 80-90 degrees. 1-3-5-7 are 500 plus degrees Fuses are good, new walboro 255 pump, new injectors, new distributor, fresh tune up Any insight? Idk what to check next could it be a grounding issue? I did search a lot of threads for hours and I can't find an answer.
Thanks, John
Old Jan 3, 2015 | 08:34 PM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
Re: 90 5.7 runs rough no power and no combustion on pass side help me solve I'll payp
You said inj fuses are good but did you check voltage to that bank inj? Put a noid light on the inj wiring to make sure it is pulsing
On a 91 it is a pnk/bulk from c207 g that is the hot wire and gnd is being switched from dk grn wire going to the ECM c2 c12 on my schematic
Old Jan 3, 2015 | 09:06 PM
Transmission: t56
It is pulsing, I did a noid test earlier today.
Old Jan 4, 2015 | 07:01 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
HIGHLY unlikely with the two cross overs in the rail but, clogged fuel rail? Just about everything that could go wrong would affect both sides except the injector pulse and you checked that. Maybe check for a leak at the manifold gaskets for that side?
Old Jan 4, 2015 | 07:17 AM
Transmission: t56
I'll test vaccume and for intake leaks today and report back.
Old Jan 4, 2015 | 07:22 AM
alan91z28's Avatar
COTM Editor
How about have you pulled a plug and confirmed it is wet. Ie are you getting fuel in the cylinder.
Also then how about spark. Do plugs on that side give you a spark with a tester touching that head. Does the head somehow not have a good ground
Fuel, air, spark to at least get to the point that side fires
Old Jan 4, 2015 | 08:10 PM
Transmission: t56
I found the problem guys. I don't know how but the fuel rail and injectors were clogged on 2-4-6-8
Old Jan 4, 2015 | 08:17 PM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
How well does the injector cleaning fluid that you add to the fuel tank work on TPI cars?
Old Jan 4, 2015 | 08:37 PM
Transmission: t56
Old Jan 4, 2015 | 08:40 PM
Transmission: t56
Not well enough to clean these! ⬆️
Old Jan 4, 2015 | 08:47 PM
Wait....I was right with the clogged rail? Do I win a prize? Kidding. I don't know how many people have definitive proof of additives making a difference. Not saying none of them do but real first-hand accounts are probably rare. I've used Lucas injector cleaner and notice a mpg improvement on my LT1 but that doesn't prove anything.
Old Jan 4, 2015 | 08:54 PM
Transmission: t56
I've worked on A lot of tpi's and I've never seen anything like this crap lol
Old Jan 4, 2015 | 10:09 PM
peterc005's Avatar
Transmission: T700
What would have caused that muck?
Old Jan 4, 2015 | 10:31 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
How long has this car been sitting? Fuel filter ever been changed?
Old Jan 4, 2015 | 11:10 PM
Transmission: t56
Ethanal... Not sure
Old Jan 4, 2015 | 11:13 PM
Transmission: t56
Only has 32k original miles it sat most of it's life in a garage. I just went through the entire fuel system new walboro 255 pump flushed tank, lines and fuel rails and another new set of injectors the car runs perfect now.
Old Jan 5, 2015 | 03:21 AM
peterc005's Avatar
Transmission: T700
Race gas additive can leave that type of deposit.
Make sure you change the fuel filter and maybe check inside the tank.
Frozer!!!
Jan 19, 2024 04:55 PM
jharrison5
Aug 19, 2015 05:53 PM
wruiz
Aug 11, 2015 02:59 PM
Sherpajames
Aug 7, 2015 06:56 PM
3rdgenparts
Aug 5, 2015 11:57 PM
