my 1990 5.7L wont accelerate at wot
Car: 1990 Iroc-z
Engine: LS3/LSA blower
So my 1990 5.7L iroc wont accelerate at wide open throttle the rpm's wont go past 3000 and im pretty sure its not my tranny....things I just replaced within the last month, new distributor, iac, tps, ignition coil, coolant temperature sensor, intake manifold and gaskets, injectors, egr, and still doesn't advance when it try ti accelerate fast.... any suggestions will help thanks
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Re: my 1990 5.7L wont accelerate at wot
Its your plugs and wires. i had the same issue back in the day, but 3rd gear (only) at wot.
Car: 1990 Iroc-z
I will give that a shot because I didn't change those two items .. .thanks I will let u know if that solved my issue. ..thanks again
Car: 1990 Iroc-z
So I bought some ac delco rapidfires and set of 8.5mm msd wires, but waiting on the wire set i should have them by friday and like I said thanks once again and hopefully this fixes my problem too
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
How old is your cat? If its effed up bad enough it can choke your motor like that.
Car: 1990 Iroc-z
Its only a year old but that realy doesnt mean anything because about 3 months ago my cat was bright red could also be that, if the new wires and spark plugs don't solve this issue I will cut it out and see what happens
Engine: LB9, LS1
If your cat was glowing its ****ed up.
Car: 1990 Iroc-z
Car: 1991 Camaro Z28 Clone
Engine: 350 w/TBI
Transmission: WC T-5
Axle/Gears: Spicer 3:73 Auburn Posi
Did it solve yours?
Car: 1990 Iroc-z
So it wasnt my cat...still kept doing it with it removed...had my fuel pump replaced and solved my issue. ..
Engine: 350 w/TBI
Pac J
May 17, 2020 10:44 AM
HoosierinWA
Oct 7, 2015 10:15 AM
