Fan switch problem....
Old Mar 3, 2015 | 08:17 PM
Calixbwsx's Avatar
Car: 89 Iroc
Transmission: 700R
My car started overheating so I decided to take it to my mechanic.turns out my fan switch is coming on at 240 which is way too late.so I bought a jet performance fan switch 60600.the problem is now the switch works but comes on at 167 and my fan won't shut off.i have tried 5 other fan switches and I cannot fix this issue.my mechanic can't figure it out and I'm all out of suggestions.i don't want to add a manual switch I rather fix the issue but I cannot find anything else. My radiator and thermostat are good and coolant sensor is also good so I don't know what else to do. Can someone please help..
Old Mar 3, 2015 | 09:31 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Fan switch problem....
Just to let you know,the fan is supposed to kick on at 235
Old Mar 3, 2015 | 09:54 PM
Calixbwsx's Avatar
Car: 89 Iroc
Transmission: 700R
Yea but it won't even turn on at 240.and my mechanic refused to let the car get any hotter than that so we shut it off..but fans don't come on at any tempature wether it's at 230 or at 260.
Old Mar 3, 2015 | 10:02 PM
deadtrend1's Avatar
What temp thermostat is in it now?
Old Mar 3, 2015 | 11:33 PM
Calixbwsx's Avatar
Car: 89 Iroc
Transmission: 700R
It has the stock t stat
Old Mar 4, 2015 | 10:33 AM
irockid43's Avatar
Car: 86 IROC-Z
Engine: 355
One option would be to have your prom tuned to come on before it gets that hot. But maybe there is another issue. Are you sure the thermostat is working properly? Also, if you haven't already, you might check your fan relay. Also, if you have a thermal gun, you could verify that your gauge is reading accurately. Hope that helps.
Good luck!
Old Mar 4, 2015 | 10:45 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Fan Relay, Coolant Temp Switch, T-Stat. Are the fans still wired stock? Secondary fan comes on when AC is turned on and at a higher temp than 240, just don't know that number off the top of my head
Old Mar 4, 2015 | 10:47 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
stock what?? 195???
Old Mar 4, 2015 | 01:47 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
240 by what, the gauge or did you do an IR temp gun check?
My gauge reads almost 30* hot.
Old Mar 4, 2015 | 07:58 PM
Calixbwsx's Avatar
Car: 89 Iroc
Transmission: 700R
Got 240 with the gun not the gauge
Old Mar 5, 2015 | 10:56 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
You've got an 89 350ci so I assume that you've got duel fans ?? If you've got duel fans then the primary fan is controlled by a signal sent by the ECM.
The secondary fan is the one that kicks on by the AC system and the temp switch in the pass side head. It's stock ON setting is 238 degrees.
These are from a 91 shop manual,.... but they might help !
Old Mar 5, 2015 | 01:28 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I used a SW555 switch. Comes on at 210 and got it at autozone.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
