Would this make for a good breathing combination?
Old Jun 27, 2015 | 09:02 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I'm researching some parts to get a bit more out of my car. It started with me just wanting to ceramic coat my headers, which then led to an auto to 5 speed swap, now I want heads, a bigger cam, and a better intake. Again, I just wanted to ceramic coat my headers...which I did. Anyway I was looking at these heads:
Trick flow heads: http://www.summitracing.com/int/part...ions/year/1987
or
Summit heads: http://www.summitracing.com/int/part...2108/overview/
A comp 08-502-8 cam: http://www.compcams.com/Company/CC/c...?csid=195&sb=2
And either a FIRST, TPIS, or Edelbrock 3890 runners and lower. To be honest, I'm leaning to the Edelbrock. For one, I like the look of the TPI, and it appears to be a direct bolt on. From what I understand the FIRST requires all sorts of modding to get it to fit, and the TPIS needs fuel rails and I don't know what else. I also do not race this car. It's just a street rod for me so I don't want or need some high RPM screamer. Just wondering what you think of that setup?
Old Jun 27, 2015 | 06:54 PM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Re: Would this make for a good breathing combination?
Anything (pretty much...) that says, "Edelbrock" on it is basic junk.
Old Jul 2, 2015 | 06:28 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
That's not true at all. I'm not Edelbrock's biggest fan, but making a blanket statement that all their stuff is junk is dishonest and misleading.
That being said, the Edelbrock base does not outflow the stock base unless you port it. I have an Edelbrock base on my GTA that I ported and it handily outflows an unported Accel base. Do a search on here about the Edelbrock base and how much it flows and you'll see what I mean.
Old Jul 2, 2015 | 08:18 PM
Car: 88 IROC-Z
Re-read the post, because you have not done so.
Old Jul 2, 2015 | 09:55 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
They way I read it you are calling everything Edelbrock makes junk. Care to add some additional clarity for us egg heads with poor reading comprehension? Obviously you're an expert all their products so please enlighten us.
Old Jul 3, 2015 | 04:38 PM
Car: 88 IROC-Z
"Anything (pretty much...)"
Old Jul 4, 2015 | 12:47 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Edelbrocks quality has gone down over the years.
colton_carlson
Mar 8, 2019 12:21 PM
armybyrd
Dec 5, 2015 09:22 AM
Reborn756
Sep 4, 2015 03:42 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
Linson
Aug 21, 2015 02:12 PM
