heads call for autolite 3923 but i want rapid fires???
Old 07-13-2015, 04:06 PM
1989formula5.7l's Avatar
Car: 89 formula
Engine: 350 tpi
I have a 89 formula with a new pre 86 gm crate motor and i purchased a set of PRE 86 skip white pro comp ALUMINUM heads a while back. Im running a tpi setup with slp runners, ported lower intake and ported plenum to match the runners, bosch 3 24lb injectors with adj regulator, 52mm tb and a comp 480 480 with 1.6 rr, edelbrock headers and dual flowmasters. Skip White recommends the autolite 3923 or NGK4544 for a colder plug but I would like to run ac delco rapid fires (my personal favorite) or regular delco. I tried researching on here and google and I couldnt find anything. Anyone know what part number rapid fire plugs or regular ac delcos I need? THANKS!!
Old 07-13-2015, 06:17 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: heads call for autolite 3923 but i want rapid fires???
spark plug cross reference....http://www.sparkplug-crossreference..../AUTOLITE/3923
Old 07-14-2015, 07:10 AM
Car: 89 formula
Engine: 350 tpi
THANKS!!
Old 07-27-2015, 12:07 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
imo plug is a little cold running those same ones myself on a 383 with a large cam/heads/compression was much happier (made more power)with the 3924. Cheap enough to swap out though if you dont like one or the other
CRFred
02-07-2016 11:39 PM
86IROC112
08-21-2015 07:20 PM
86White_T/A305
08-17-2015 12:16 AM
apie2546
08-10-2015 05:43 PM
Quick Reply: heads call for autolite 3923 but i want rapid fires???
