data logging a 7165 ECM
Old Feb 12, 2016 | 02:52 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
i have come to the conclusion that i need to data log my 86 TPI car . at this moment i know nothing , EXCEPT that a data log could help me diagnose a cold weather problem im having . my question is ,,, which is better "tunerpro " or something else ? . and whats all this "some 7165 ECMS wont allow a data log ?? . how can i have reasonable sucess ? any and all reccomendations or tips are welcome
Old Feb 12, 2016 | 11:45 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: data logging a 7165 ECM
I use TurnerPro Rt. I have recently got into tuning. The 7165 ecm can be a problem connecting when datalogging. It's a crap shoot, some will datalog all day and others will only datalog for a few minutes. I can datalog for about 15 minutes before getting errors. The 7165, maf, ecm's can be problematic when datalogging. Not sure why. I've been thru about 3 ecm's with varying results when datalogging. I researched and made recommended changes to the settings to include a timeout during the data stream and that seems to help. The members on this forum are very knowledgeable and should be able to get you on the right track.
The hardware (cable that connects the ALDL link to the laptop USB port), I got from Moates.
Old Feb 13, 2016 | 06:58 AM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
If you can find on a '259 is plug n play interchange with '165 it also has 2 instead of 1 inj drivers.
Old Feb 17, 2016 | 03:49 PM
mrestrictrplate's Avatar
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
I need to learn how to datalog so I can figure out mycars w tpi. I have 3 so there's always something going on.
Old Feb 23, 2016 | 09:24 AM
KCG's Avatar
KCG
Car: 89 IROC
I data logged with TTS Datamaster. Since its free, I thought it would be a pretty common program to use. It seems simple enough to use, but when I posted the file and asked some questions about the results, I got next to no replies. I'm not sure why.
So, Is TunerPro RT the one eveyone uses?
Old Mar 19, 2016 | 07:44 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
tunerpro rt is what I use, setting up the programs for datalogging is a pain in the ***, my 165 ecm will only datalog with the resistor on the cable in place which causes issues.
Old Apr 13, 2016 | 08:18 PM
tmellott89's Avatar
Car: 88 Iroc. 12.60@ 107. 1.72 60'
Engine: 350 paxton sn93 36lbs injectors
Axle/Gears: 9in. 390s
I have my resistor set all the time for data logging also. I didn't know it could cause issues though? If it's not set I have a high idle. What issues can it cause?
Old May 27, 2016 | 11:41 AM
KCG's Avatar
KCG
Car: 89 IROC
So some months later, what did you use?
Have any results, comments or suggestions?
Old May 28, 2016 | 08:43 PM
Car: 86 IROC
Engine: 5.0 TPI
no , unfortunately , i hit a oak tree with my beloved camaro . to repair it would involve replacing the entire front sub structure. so , i have found another 86 IROC . its also a real "B4Z" car. that has 70,000 miles and is a one owner car . parked in 1990 due to the original owner dying. trying to score it as we speak
Old May 29, 2016 | 02:09 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Bring that thing home.
Old May 29, 2016 | 10:06 PM
Car: 86 IROC
Engine: 5.0 TPI
im trying , unfortunately the person selling it has a delusion that its worth $5,000. and it dosent run , due to it being parked in dry storage for 26 years
p-balin432
Feb 16, 2016 09:43 PM
knightinblackar
Feb 8, 2016 11:02 AM
JohnFB
Jan 31, 2016 06:47 PM
Coltsfan1
Jan 20, 2016 07:59 AM
