Intake manifold splash guard
Old Mar 2, 2016 | 04:42 PM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
Got an Edelbrock hi-flow intake installed last summer with AS¤M runners.
Car runs fine, but noticed when cleaning the stock base-plate, that the splash guard was still on it.
I dont remember if the Edelbrock had one, but I believe it didnt.
Guess it should have been transferred?
Drove the car maybe 2000 miles last summer, no problems.
What is the purpose of this splash guard, and does it make much difference?
The inside of the splash guard has a layer of black oil on it.
Please respond if You know, not just guessing, that Im doing myself
Old Mar 4, 2016 | 03:22 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Intake manifold splash guard
Splash guard? How about a pic of the piece in question.
Old Mar 4, 2016 | 10:34 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Under the intake, the metal shield that bolts on to the manifold. I have no idea how necessary or not it is.
Old Mar 5, 2016 | 07:51 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The splash guard is to prevent oil from burning and carbonizing to the bottom of the intake. The exhaust passages for EGR makes for hot spots that will do this.
If the Edelbrock base doesn't support EGR then no issue with no splash guard. Although some state that it helps keep the intake cooler without the hot oil splashing on it.
RBob.
Old Mar 5, 2016 | 08:04 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
I bought an Edelbrock Hi Flo back in 2010-11. I had to transfer my guard to the new intake. If you only run about 2000 miles a year, I would think it wouldn't hurt anything, but you could call Edelbrock and get their opinion too.
hotrodjames
Mar 23, 2016 02:05 PM
Cross fire Sid
Camaros Wanted
22
Mar 17, 2016 03:48 PM
Xzavior1818
Mar 2, 2016 04:49 PM
shugart111
Feb 27, 2016 01:01 AM
Dartht33bagger
Feb 26, 2016 02:05 PM
