Tpi lb9 help needed
Old May 12, 2016 | 11:00 AM
Rlmirocz's Avatar
Tpi lb9 help needed
Hey everyone. I'm having a problem with my tpi. Sometimes When I turn the key to turn it on, it makes a weird noise and the engine doesn't even rev. I will post vid. You might need to turn up the volume. Any help appreciated.
Also I wasn't really sure where to post this.
Old May 12, 2016 | 11:42 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: Tpi lb9 help needed
Sounds like the starter is spinning, but maybe the spindle isn't extending out of the starter thus not making contact with the flex plate? The other sounds just sound like fans.
Old May 12, 2016 | 04:15 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I didn't listen to the video so I'm going on faith here.
If the starter is spinning, it has to be kicking out the drive (Bendix). Unless the fork (for lack of a better term) is broken. Most likely the drive is bad.
malcontents
May 2, 2016 08:52 PM
Veaceonee
May 1, 2016 11:50 AM
astout82
Apr 28, 2016 10:11 PM
hotrodaj
Apr 25, 2016 02:33 PM
BobKnake
Apr 23, 2016 08:49 PM
