Which injectors to get?
Old Aug 14, 2016 | 06:13 PM
Logan Bryant's Avatar
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
I have a mostly stock LB9, minus the exhaust, and the car is running super rich. Replaced all vacuum lines, new egr, fuel pressure regulator diaphragm. So I think some of the injectors are stuck. So this brings me to the question Bosch d2 or d3?
Old Aug 15, 2016 | 10:02 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Which injectors to get?
Bosch III's. Southbay Fuel Injectors....19lb
Old Aug 16, 2016 | 01:48 PM
maks10's Avatar
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Ever test resistance on them?
Old Aug 16, 2016 | 03:15 PM
BOTTLEDZ28's Avatar
Transmission: A4
Is this test accurate enough to determine if an injector is bad or not?
Old Aug 16, 2016 | 03:26 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
NO...........you can have resistance in the range and and still have bad seals causing leaking.
My God... the injectors are 31 years old! Change em. You won't regret it.
Old Aug 16, 2016 | 05:24 PM
maks10's Avatar
Car: 1990 Trans Am
worth a test before paying money for new injectors takes seconds and gives a confirmation
Old Aug 16, 2016 | 05:35 PM
maks10's Avatar
Car: 1990 Trans Am
Also maybe read your plugs if one injector is stuck I would think that plug would show rich as well...just more confirmation
Old Aug 16, 2016 | 06:00 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
You know something maks10, you're right, I stand corrected on running out and spending money on new injectors. I wouldn't want to do that either. You saved him $160. But the original question was which ones to get. I had figured, silly me, again, that he performed all those checks. I guess he did not. Good luck with the fix Logan.
Old Aug 16, 2016 | 06:11 PM
maks10's Avatar
Car: 1990 Trans Am
Yea not sure if he has done the basics either just wasn't mentioned out of the list of things...I agree the flow won't be confirmed without a bench test...and he did only ask for injectors so technically the answer was given
Old Aug 16, 2016 | 06:16 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
I tested them and they all tested 15.9 to 16.4. I pulled spark plug 1&2 and they were really black, and there was gas up around the threads. Anything electrical that would go bad to replace either? Somewhere it is dumping in too much fuel.
Old Aug 16, 2016 | 06:26 PM
maks10's Avatar
Car: 1990 Trans Am
Pull all plugs and compare... Codes would hopefully show with sensors but not all the time
Old Aug 16, 2016 | 06:29 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
That's the thing, no codes.
Old Aug 16, 2016 | 06:34 PM
maks10's Avatar
Car: 1990 Trans Am
When did it start running rich? What exhaust was done? Your o2 could be the culprit depending if the exhaust work affected that site...usually a code would show if it was disconnected or fouled but just trying to rationalize the sudden change
Old Aug 16, 2016 | 06:37 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
It started running rich about a week ago. It has hooker shorty headers, no cats and a phab catback (SLP loudmouth copy). I replaced the o2 sensor about a year ago.
Old Aug 16, 2016 | 06:48 PM
maks10's Avatar
Car: 1990 Trans Am
Also how does it idle and drive? Since there's no codes at moment I'd try to back track to anything done and leave sensors alone at the moment...is ur fpr adjustable?
Old Aug 16, 2016 | 07:00 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
It will idle, and blow out black smoke. I drove it, got it warm, and let it set and idle. It would bog down, then the idle would get raised back up, and then blow out black smoke. It will bog out when I stop at stopsigns too.
Old Aug 16, 2016 | 07:01 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
It would eventually die from to much fuel, when idling. It doesn't have an adjustable fuel pressure regulator.
Old Aug 16, 2016 | 08:21 PM
maks10's Avatar
Car: 1990 Trans Am
Tough to say maybe someone can chime in I can see why you thought maybe stuck injector...2 things that come to mind with your symptoms are the iac and cts which would change your fueling...still try to rule out as much as you can before you have to purchase something
Old Aug 17, 2016 | 11:22 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
My buddy is having the exact and I mean exact same issue. Rich, black smoke, idles up and down and runs like crap. His problem popped up out of the blue also. We have changed and checked every sensor and replaced the injectors. Now his injectors OHMS were all over the place and needed changed. When we finished it made absolutely no difference at all. His car is at a shop as I type this and they believe it is the ECM. They also have checked all the systems and can't find any of them not working. I will let you know what they find.
Old Aug 17, 2016 | 08:23 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Bosch design 3 from south bay, are on the way. Should be here Saturday. Will update then.
Old Aug 17, 2016 | 08:58 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
I put bosch III injectors (19 LB) in my LB9 .... what a difference, went from grizzly bear to Cadillac smooth. You will be happy.
Old Aug 20, 2016 | 05:05 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Does the Bosch III's require fiddling w/ to install? Or, direct fit?
Old Aug 20, 2016 | 05:19 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
They are a direct fit, no clips. Just follow the directios on installing them, you be fine
Old Aug 23, 2016 | 10:08 PM
Car: 90 Iroc Vert
Engine: 5.0L
Piece of cake ... just check for leaks before you put the TPI (runners & Plenum) assembly back on. Had a pinched oring on both my GTA and Camaro.
I used motor oil to lube them in, its a challenge to get the fuel rail onto the injectors and seated properly without a little bit of force.
Install injectors, the fuel rail/reg/fuel lines ... then do a quick leak test.
Also get a new fuel reg and an O ring kit for the fuel rails, new gaskets for the TPI. I also put a new egr valve while it was open.
Attached Thumbnails Which injectors to get?-fi-job-005.jpg   Which injectors to get?-fi001aaa.jpg
Old Aug 24, 2016 | 10:03 AM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Good call on the CTS sensor.I had 90 chevy truck,it ran excellent for two years. I went for a ride one day and the thing died on me .A friend saw me on the side of the road and took a look under the hood whill I kept the truck running .He said the throttle body injectors were dumping fuel.I barely got it home and then started changing sensors.It didn't help.My buddy comes over with his scan tool.He said it was reading -40 degrees.It was the CTS only sensor I didn"t change.Long story short it ran perfect again.
Old Aug 29, 2016 | 08:22 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Got the injectors installed Sunday. Used dish soap on both orings on the injectors. No leaks at all. Ended up changing the cts sensor as well since I had it all apart. Runs like a champ now. Thanks everyone for the help
Old Aug 30, 2016 | 07:13 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Great to hear Logan! Thanks for the update.
Old Sep 1, 2016 | 07:45 PM
southbay08's Avatar
Hey Logan...awesome news.
Dskeezy16
Apr 4, 2016 08:01 PM
Sals82Z28
Aftermarket Product Review
Jan 17, 2001 10:55 AM
Fastbird
Dec 29, 2000 07:13 AM
sweetgn
Nov 14, 2000 07:14 AM
