WHat kind of price should I expect?
Old Dec 29, 2001 | 03:47 PM
HM Murdock's Avatar
Car: 1988 Formula and 1995 LT4 Z28
Engine: 305 TPI and 361 LT4
Transmission: M5 and stalled A4
If I have my TPI 305 Rebuilt?
Thanks in advance...
Old Dec 29, 2001 | 06:55 PM
ImportsRsloths's Avatar
About the same price to have an already built 350 put in which id guess around $2500-$3000
Old Dec 30, 2001 | 01:01 AM
HM Murdock's Avatar
I figured, but I would like to keep it nimbers matching...
Old Dec 30, 2001 | 01:02 AM
HM Murdock's Avatar
WHat about boring it out to a standrd 350 size? Can you do that with a 305?
Old Dec 30, 2001 | 01:11 AM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
Transmission: 6 spd.
Axle/Gears: Ford 9" 4.11
I'm getting ready to rebuild my 305 tpi, I've found kicks for 400-500 dollars to rebuild, don't know how much the labor is gonna be yet. I'm gonna go with the powerhouse stroker kit, it's the one that was used on the silver streak in super chevy magazine, it's $600. BTW you can't bore a 305 to 350, it's the same block but I believe the cylinders are closer together on a 305 and you can't bore them as much. Hope this helps.
Old Dec 30, 2001 | 02:17 AM
HM Murdock's Avatar
Yeah, it does help...I am new to the 305 thing, only ever had 350's before this...
Old Dec 30, 2001 | 02:50 AM
Earl 87gta's Avatar
If you pay some one to pull the motor hear and put in a creat motor it is 500 in labor plus the engine. If you have yours rebuilt to stock no performance work done it would coast 100 to have the block done this is not boring to a larger size this is just clean and hone add 50 to 100 more for an over bore then 50-100 to have the cranke turned. 100-200 if you have it balanced 200 to have the heads reserficed and a three angle valve jog done 200 to 300 for engine rebuild kit with out pistons this is with all seals rings barings oil pump or 300 + if you need pistones depending on type plus at least 200 to have the mashine shop bolt it all together and mabe even 100 to diasembel it all. prices for your area may be more or less but this is the going rate hear. Plus you will probly have give or take 200 mabe 300 in other parts like water pump plug wires ditribitor cap plugs belts al that small stuff that most dont think aboat when planning their rebuild.
Old Dec 31, 2001 | 11:21 AM
87kevroc's Avatar
Car: 1987 Chevrolet Camaro Z28 IROC-Z
Transmission: TeamTripp Performance
You should be able to get it done for less than $2500. My 350 was done for about $2300, which included a new oil cooler (> $200 !) that I hadn't planned on. The job did include the extras (ign. components, belts, etc.) mentioned above. Check this link (scroll to bottom) for more detail on what was done during the rebuild.
neilb
Sep 15, 2015 05:06 PM
pimprs
Sep 10, 2015 03:34 PM
scottmoyer
Sep 7, 2015 07:06 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
IROCZ1989
Sep 4, 2015 11:54 AM
