lb9
Old Dec 20, 2016 | 05:23 PM
junglejim75686's Avatar
Car: 92 Z28 CONVERTIBLE
Transmission: AUTO
lb9
what is the difference between the 205 hp lb9 and the 230 hp lb9 in 92
Old Dec 20, 2016 | 05:56 PM
TURBOTOMMY's Avatar
Car: 92 T.A.
Engine: 5.0TPI
Transmission: 5 spd.
Re: lb9
25hp
Old Dec 20, 2016 | 06:12 PM
Transmission: AUTO
Re: lb9
if you dont have anything informative to add then do respond
Old Dec 20, 2016 | 06:43 PM
TURBOTOMMY's Avatar
Car: 92 T.A.
Engine: 5.0TPI
Re: lb9
Not trying to poop on your thread..All I'm saying is that in this day n age where we have 300hp minivans running around it really doesn't matter now does it,,,honestly 205h 230 HP even the 350 at 245hp,,,,that's just not very much nowadays..
Get a game plan together that will put you anywhere from 350-450hp and your back on a level playing field....
Old Dec 20, 2016 | 07:50 PM
Transmission: AUTO
Re: lb9
i didn't ask if it was fast. when i wanna go fast i get my other car out of the hauler all i asked what the difference between the two engines were. i race usmts modifieds so i know what hp and tq is
Old Dec 20, 2016 | 08:21 PM
TURBOTOMMY's Avatar
Car: 92 T.A.
Engine: 5.0TPI
Re: lb9
Different Exhaust,,Cam,,And Ecm.Is That Good Enough Fo ya
Old Dec 21, 2016 | 06:12 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: lb9
Other than the dual cat option the exhaust was the same.
Big difference was the cam - you got the L98 cam in the LB9 5 spd motors.
Old Dec 21, 2016 | 07:21 AM
Transmission: AUTO
Re: lb9
That's what I was trying to figure out. I know that my car has the 5500 redline but I didn't know if the put diff cams in with the same redline
Old Dec 21, 2016 | 07:35 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: lb9
91-92 Speed Density Lb9s all got the "350" cam. The difference was in the exhaust manifolds and the dual cat option on the 5spd models. It helped to make 25 more HP but honestly I'm pretty sure those LB9s made more than the advertised 205 HP.
Old Dec 21, 2016 | 08:01 AM
Transmission: AUTO
Re: lb9
I have put headman mid length headers with the headman y pipe and a 2 chamber flowmaster with no cat so I'm sure that has brought it up a little. The little car runs good and always has
Old Dec 21, 2016 | 09:46 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: lb9
They had different exhaust ?
The ecms were the same man vs auto calibrations were different .
Old Dec 21, 2016 | 10:24 AM
PurelyPMD's Avatar
Engine: LB9
Re: lb9
That's interesting - I hadn't realized that until you said it and I check the parts book.
Cam was the same with those motors those years but different from prior years. Any idea what the difference was?
Old Dec 21, 2016 | 10:51 AM
Engine: Lb9
Transmission: M20
Re: lb9
Compression ratios were the same, iirc same heads
Looks like TPI's could come either with a single cat 2.25" exhaust (rated at 205 HP) or the dual cat 2.75" exhaust (rated at 230 HP).
Old Dec 21, 2016 | 10:54 AM
TURBOTOMMY's Avatar
Car: 92 T.A.
Engine: 5.0TPI
Re: lb9
Uhhh no,,different ecm's for different year's,,,there not all the same...Some lb9's had 2 cat's some had 1,,,,,hence "different exhausts" as in not the same...
Old Dec 21, 2016 | 10:59 AM
TURBOTOMMY's Avatar
Car: 92 T.A.
Engine: 5.0TPI
Re: lb9
If his didn't come with the 3.42 ring n pinion,,,he's got the small cam...If his is the ragtop,,its got the small cam..
Old Dec 21, 2016 | 11:17 AM
Engine: Lb9
Transmission: M20
Re: lb9
Apples to apples
Old Dec 21, 2016 | 12:23 PM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Re: lb9
I think the exhaust manifolds are the same as by buddy has a 92 TPI and my 91 look exactly the same. He has the dual cat system. So if I read this info right the only difference is the dual cat system with the larger pipe. If that is the case I am thinking by just doing a complete exhaust you could theoretically gain 50+ HP?
Old Dec 21, 2016 | 01:17 PM
Transmission: AUTO
Re: lb9
Gm only list one cam number for the 305 and 350 so the cams were the same they used a small cam in the 80s the only thing I can find different is the exhaust
Old Dec 21, 2016 | 04:17 PM
TURBOTOMMY's Avatar
Car: 92 T.A.
Engine: 5.0TPI
Re: lb9
part#;s 10111773 10066049 10088155 14094097 14088843.......All these cams are lb9 cams,,,and they are all different specs,,and theyre all teeny tiny inho
Old Dec 21, 2016 | 05:32 PM
TURBOTOMMY's Avatar
Car: 92 T.A.
Engine: 5.0TPI
Re: lb9
Apologize,,,i just noticed your only asking about the 92 year model...I retract all my previous posts here,,,,sorry
Old Dec 21, 2016 | 08:31 PM
Drew's Avatar
Re: lb9
The difference is primarily the exhaust. If you look up the exhaust in the GM parts catalog, the higher output 305 used the same exhaust as the 350. The lower output version used different manifolds, a single cat, and I want to say even the TBI intermediate pipe, muffler, and tail pipes.
The lower output cars usually didn't come with 245/50R16 tires either. I wouldn't be too surprised if they have a different memcal with a speed limiter, and potentially other details as well.
Old Dec 21, 2016 | 08:40 PM
Drew's Avatar
Re: lb9
Old Dec 21, 2016 | 10:27 PM
Transmission: AUTO
Re: lb9
Very informative thank you. my car did come from the factory with 235/55/16 instead of the 245/50/16 my car runs well with the headers and y pipe it also has a chip and under drive pullys. And I will doing a gear change soon. Thank you everyone for the info
Old Dec 22, 2016 | 07:02 AM
TURBOTOMMY's Avatar
Car: 92 T.A.
Engine: 5.0TPI
Re: lb9
Don't know what gears you have,,but mine had 3.42 before the 1st rear broke...I replaced it with a recycled rear with 2.73s,,big mistake..The car slowed down into the low 16in the 1/4..It didn't take long to tear that rear up,,so I rebuilt the the rear correctly with 3.42s,,performance restored..If I were good it again it would have 3.73s,,I've ridden in and driven 3.73 5.0l 3rd gens and IMHO that's the perfect ration for the 5.0l..
On a side note,,we've also installed 3.73s in a friends 89roc with a 350..Big mistake,,,that was way to much gear for for a 350,,turned it into a tire burner. Good luck,,sorry about the previous posts..
Old Dec 22, 2016 | 09:14 AM
Transmission: AUTO
Re: lb9
It has 2.73 in it now I'm thinking about putting 3.42. I do all my own rear end setups as I mention before I race modified dirt cars so over the years I've learned to do most everything except building transmissions and painting nice cars. I don't car how fast the car is I was just wondering what the difference between the two were and I think I have got my answer. I appreciate your info
Old Dec 22, 2016 | 12:06 PM
TURBOTOMMY's Avatar
Car: 92 T.A.
Engine: 5.0TPI
Re: lb9
You will love them...
Old Dec 22, 2016 | 12:17 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: lb9
3.42s probably the perfect gear for these cars. I like my 3.73s it just that 1-2 gear is so close it will sometimes spin rite through 1st and into second. I have a spare set of 3.23s I may try next time or maybe go with 3.42s myself. Surprisingly the 3.73s didn't really hurt my gas mileage at all.
Old Dec 22, 2016 | 12:45 PM
Transmission: AUTO
Re: lb9
I have a set of 4.10s out of an old race race car that are practically brand new every other gear that I have are for. A ford 9in everything from the mid 2s to the mid 7s and prob about 6 or 7 sets of 6.50
88Camaro350
Sep 3, 2022 10:48 PM
resop27
Jul 17, 2009 12:44 PM
ohiothirdgen
Apr 17, 2008 09:35 PM
rawley2
Nov 23, 2004 03:43 PM
whitess
Jan 25, 2004 10:55 AM
