Smog Pump Removed; Needed Changes to Bin
Old Jan 14, 2017 | 12:22 AM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
I have a 87 Monte Carlo SS with a 89 MAF 350 TPI conversion. I've been running it for about 4 years. Last week my smog pump crapped out. Was making a terrible noise. Since New Jersey no longer does emission testing on cars of my vintage, I removed the smog pump and air valves and installed a bypass pulley from TPI Parts.net. My question is; what do I need to change in the bin? I'm running the ARAP bin with 6e mask.
Old Jan 14, 2017 | 10:04 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Smog Pump Removed; Needed Changes to Bin
Set this parameter to 150* C (302* F):
LC324 FCB 73 ; 14c COOL, IF LT THRESH, DIVERT AIR
That will force the ECM to always divert the air, basically turning off the AIR functionality in the ECM.
BobR.
Old Jan 14, 2017 | 10:46 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Another way is to enter ff at $324 in the hex editor.
Old Jan 15, 2017 | 08:28 PM
Fred SS's Avatar
Transmission: 2004r
Thanks RBob and Tuned Performance. I'm using TunerPro Rt, basically a beginner with it, but I've been tuning (editing some parameters) for about a year now. I have no idea how to do hex editing, but I'll google it. I gotta learn sometime.
Old Jan 15, 2017 | 08:45 PM
Engine: Lb9
Transmission: M20
Once you have your .bin loaded hit control-h .
This will bring up the hex editor.
Go to $324 type ff then save the .bin
Old Jan 17, 2017 | 10:09 PM
Fred SS's Avatar
Transmission: 2004r
Thank You Tuned Performance. I actually did find the hex table by stumbling around TunerPro. But wasn't sure how to find $324. How did you learn this stuff?
Old Jan 17, 2017 | 10:26 PM
Engine: Lb9
Transmission: M20
Trial and a lot of error lol, glad you figured it out.
There is a learning curve to make more use out of tunerpro rt. It's way better than tuner cat witch I started out using years ago.
Old Jan 18, 2017 | 03:19 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Tuned: Just to be sure it is where the cursor is right? Replace '40' with 'FF'?
Old Jan 18, 2017 | 09:09 AM
Engine: Lb9
Transmission: M20
The cursor shows the address, it's where the | is . The value on this tune star is 49 , that would need to be changed to ff .
Old Jan 18, 2017 | 09:18 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Everytime I read one of these threads it is like reading French.
Id love to have the time to try and learn it though. Hats off to those that do. Maybe one day I'll jump into it.
Old Jan 18, 2017 | 01:07 PM
Engine: Lb9
Transmission: M20
I added air divert coolant temp to the scalars.
I have also added more flags.
File Type: zip
Old Jan 18, 2017 | 02:28 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
You're a legend Tuned. Hope you know that
Old Jan 18, 2017 | 08:47 PM
Fred SS's Avatar
Transmission: 2004r
Thanks for posting that file Tuned Performance. Comparing it to the standard xdf I've been using, it has several differences. I got allot to learn. You could write a book on this stuff.
