TPI 350 Stalling
Old Feb 3, 2017 | 03:05 PM
86Z28w350's Avatar
Car: 86 Z28
TPI 350 Stalling
Hello, I Purchased a 1986 Z28 back in the summer, and now I finally have some time to work on it. The first issue I have with it is that it will stall upon cold starts (unless I pump the gas) this also happens after putting it in gear, if I don't pump the gas it stalls. My cousin says it may be a vacuum leak, the garage next door says they think it may be a cam sensor. is there anything else that it may be?
Old Feb 3, 2017 | 03:10 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI 350 Stalling
Cam sensor lmfao, sounds lean injectors, fuel pressure, vacuum leak.
Is this just during startup ? If so I'd think ninth injector is faulty.
Old Feb 3, 2017 | 03:41 PM
86Z28w350's Avatar
Car: 86 Z28
It also happens when I put in gear, also when I leave it idling too long it will stall.
Old Feb 3, 2017 | 04:11 PM
Engine: Lb9
Transmission: M20
Sounds like it could be injectors and it's running rich and loading up once warm.
Once warm you can check the resistance of the injectors. They should be around 16-15.5 .
A vacuum leak usually causes a higher idle if it's a minor leak.
Or a leak between the throttlebody and maf sensor.
Check engine light on ?
Old Feb 3, 2017 | 06:50 PM
86Z28w350's Avatar
Car: 86 Z28
The Check Engine light is on, however that's another problem... a previous owner hacked up the wiring under the dash, and it wouldn't work when I tried to scan it.
Old Feb 3, 2017 | 07:28 PM
Engine: Lb9
Transmission: M20
http://www.theimportkiller.com/forum...hp?topic=420.0
Old Feb 3, 2017 | 08:43 PM
86Z28w350's Avatar
Car: 86 Z28
Thank you very much, I'm going to have to try this as soon as I get out of work on monday.
Old Feb 3, 2017 | 08:56 PM
Engine: Lb9
Transmission: M20
You might have a maf issue or a maf relay, I'd sure start with the trouble codes first.
Old Feb 4, 2017 | 08:54 PM
zero13's Avatar
Car: 91 Z28
Engine: Enhanced 5.0L
Axle/Gears: 3:42 Posi
Tuned Performance..Kudos to you..You are all over the board with answers!..And good info!.If I had a Gold star sticker..you'd get one!
Old Feb 4, 2017 | 10:28 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
He's a super helpful resource that is greatly appreciated by the community at large
Old Feb 5, 2017 | 09:43 AM
Engine: Lb9
Transmission: M20
Thanks all, if you can't get the light to blink due to hacked wiring I'll walk you through checking the ground and aldl ecm request wire.
Old May 4, 2017 | 10:46 PM
86Z28w350's Avatar
Car: 86 Z28
Hey guys, sorry for not having replied in a long time, but I finally was able to get more work done on the car, turns out that it was a bad IAC valve. I did that and a TV cable, there's now a dead spot in the throttle where it stalls. It could be a TPS, but I don't have the proper equipment yet, so I tried adjusting it mechanically, but it won't go away, along with some hesitation. Other than that she's a much different animal! (I also forgot to add that the previous owner(s) were a complete buffoon, and butchered almost ALL the wiring not in the engine bay.)
Old Jun 16, 2017 | 01:06 AM
86Z28w350's Avatar
Car: 86 Z28
I'm having a new problem, after a few weeks of it running smoothly, I've started having a similar problem, this time it's the other way around, it idles fine for a minute, however when I give it even slight throttle it dies, the car's been abused and neglected so we think it may be bad fuel (because I don't drive it very much) or could it be something else, I'm able to put it in Neutral or park and start it back up just fine, just when there's load on the engine it seems to not like it.
Old Jun 16, 2017 | 01:14 AM
86Z28w350's Avatar
Car: 86 Z28
I'm also ordering an ALDL to USB cable + software and hopefully be better able to understand what's going on using my laptop.
