BOSCH INJECTORS
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: BOSCH INJECTORS
A starter tune can be made with the injector constant changed. To finetune you would need to datalog imo.
Car: 1989 GTA
Engine: 5.7 TPI
Axle/Gears: 3.27 (Stock)
Re: BOSCH INJECTORS
I didn't think you could fit 2.02 valves into the 305 bore. Or if you were able to get heads machined to do it, there would be no real flow gain due to shouding by the smaller bore?
Re: BOSCH INJECTORS
https://www.thirdgen.org/forums/diy-...r-offsets.html
It goes beyond just changing the injector constant
gbayfisher
23
Dec 15, 2016 10:18 AM
