Won't run with MAF plugged in
Old Apr 28, 2017 | 09:55 AM
Rider91's Avatar
Basically as the title says it won't run with the MAF plugged in. Im just on the tail end of replacing the motor and it just doesn't want to run.
I'm pretty sure that the MAF isn't bad, I have 2 and tried with both,
I'm positive that everything is plugged in except for the temp sensor between cylinder 1&3 because the different connection used between 88 & 89 ,
it's currently sitting with just the Y-pipe open because I need a bit welded in
I have pulled out all the smog pump stuff and a/c plumbing and installed a set of headman headers
And timing has been set dead on 6° before tdc
my car is an 88 Iroc-z 305 TPI
Old Apr 28, 2017 | 10:10 AM
Rider91's Avatar
Re: Won't run with MAF plugged in
All the part numbers for MAF relays pull up ac relay if there's a way to test the relays before looking for new ones I wanna do that
Old Apr 29, 2017 | 12:10 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Check really hard for a vacuum leak
Old Apr 29, 2017 | 12:30 PM
Vader's Avatar
If you can measure a MAF analog output voltage with the unit connected and running it may shed some light on the root cause.
Old Mar 9, 2021 | 10:16 AM
KITT 84's Avatar
Car: 88 Trans Am = KITT
any updates i have the same issue after changing to a super ram intake
KanzlerBismarck
Feb 27, 2018 10:59 PM
badblackiroc
Feb 1, 2009 03:32 PM
camarokid54270
Oct 2, 2004 11:13 PM
joshp14
Jan 14, 2003 07:55 PM
Test King
Jul 18, 2002 02:31 PM
