max compression on 93 octane
Old May 10, 2017 | 06:44 PM
88roctpi's Avatar
I have an 88 iroc z Camaro. It has the 350 tpi engine. I plan on rebuilding this engine with crane 2032 cam, summit racing 62cc aluminum heads, and first tpi intake. I plan on putting 4 valve relief hyper flat top pistons. What is the max compression i can have and still run premium fuel and be safe?
Old May 10, 2017 | 07:13 PM
sprojam's Avatar
Car: 86 Z-28
Engine: 355 small block XR276HR roller cam
Transmission: TCI built 700r4 2000 lockup stall
Axle/Gears: moser axels auburn posi 3:73 gears
Re: max compression on 93 octane
I am not familiar with that camshaft but I'm at 11.34 to 1 and I run premium with out spark knock but have to pull some timing out. 10 to 1 is a good bench mark from what I have been told.
Old May 10, 2017 | 07:28 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I'd shoot for 10-10.2:1 max. Low rpm plus smallish cam, high dynamic cmpression, i would like 10:1. Sneak up on tune, watch the 3000-3600 rpm range. Probably only want 30-32 deg timing there if heads are decent chambers, and 34-36 overall at 4400
Old May 11, 2017 | 12:18 AM
sprojam's Avatar
Car: 86 Z-28
lol 11.5 to 1 on the Harley no problems on pump gas 11.34 to 1 I have to pull timing out in the chevy v8 probally has something to do with fuel distribution hmmm 10 to 1 lol
Old May 11, 2017 | 03:23 AM
NoEmissions84TA's Avatar
Calculate your DCR. 8.0-8.5 to 1 is the sweet spot. Heat will be the most significant factor regarding detonation.
Old May 11, 2017 | 07:10 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I have run 11:1 no problem with a big camshaft. Bigger cam bleeds off compression. It will crank less. Small cam would have alot higher cranking pressures
Old May 11, 2017 | 07:45 AM
ULTM8Z's Avatar
With a 268 cam on a 350, I get away with 9.9 on 91 octane. Originally i had 10.1, but kept bouncing off the knock sensor. I get absolutely no knocks with 9.9.
Old May 11, 2017 | 05:38 PM
88roctpi's Avatar
The cam is a 214 220 112 lsa 482 496 with 1.6 rockers.
Old May 11, 2017 | 05:55 PM
Provide the values and I will make the calculations for you.
