TPi type and spark plug help
Old Aug 4, 2017 | 05:14 AM
Defender50th's Avatar
Hello all, just joined and hope you can help. I have a Land Rover Defender with a Chevy TPi engine, a company called Overfinch used to do conversions here in the U.K.
I would love to know more about the engine and also I want to upgrade the spark plugs. Would NGK TR55IX be correct for this?
Thank you for any help
James
Old Aug 4, 2017 | 10:16 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: TPi type and spark plug help
89 and newer TPI. (Speed density)
Block casting shows 96 and up Vortec? That seems kind odd.
Old Aug 4, 2017 | 11:56 AM
GeneralDisorder's Avatar
They may have used a new crate motor and a used TPI system.
GD
Old Aug 4, 2017 | 03:41 PM
It should be all new parts, I think they started doing the conversion in 1997 and this one was about 2002.
Anyone able to advise what iridium plugs to fit?
thnaks
Old Aug 5, 2017 | 08:29 AM
Abubaca's Avatar
I have ALWAYS used AC Delco plugs for my original TPI engine. Although, If you have vortec heads to go with that block, I can't say what plug would be best. I'm sure AC Delco offers something.
Old Aug 5, 2017 | 09:35 AM
I don't think we get AC Delco over here.
do you know how I would identify if it's a vortec head?
Many thanks
James
Old Aug 5, 2017 | 03:31 PM
Vader's Avatar
If you can get Champion plugs, try RV15YC4.
Short of that, NGK 3547 should work. They're only £562.81 there:
Amazon Amazon
Old Aug 6, 2017 | 04:38 PM
ploegi's Avatar
Engine: 5.7 TPI
https://www.amazon.co.uk/NGK-SPARK-P.../dp/B0018K1FIC
Holy crap, that's INSANE.
Old Aug 7, 2017 | 01:30 PM
Abubaca's Avatar
You could always pull a valve cover and get the casting number. ...or a picture (if possible) of the cast "humps" on the front of the head. ...also, I think the manifold bolts go in straight up and down. Meaning 90* from level ground. Where regular heads thread in at an angle.
Old Aug 7, 2017 | 01:46 PM
Ty92Z's Avatar
Car: 1992 Z28 1991 RS
Engine: LB9 LO3
Transmission: 5 speeds
There would also be just 8 intake bolts, 2 at each corner and none in the middle.
