TPI Fuel Line O-Rings
Old Sep 1, 2017 | 12:46 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Anybody out there have the part number for these O-Rings for the 5.0 TPI Fuel lines?
Thanks Bob
Old Sep 1, 2017 | 06:46 PM
Drew's Avatar
Re: TPI Fuel Line O-Rings
Oh, somewhere... http://austinthirdgen.org/parts/html/main1.htm should be able to look them up. Not sure the numbers will really be all that useful. Any place short of the dealership is just going to match em up by eyeball to the random assortment.
Old Sep 1, 2017 | 07:31 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
I found them Drew. Totally unnecessary thread.
Old Sep 1, 2017 | 07:48 PM
MrMac98's Avatar
try
feed line 22514722
rtn line 22516256
Old Sep 2, 2017 | 04:12 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Glad you found replacements.You got them pretty fast,did you get them locally?
Old Sep 2, 2017 | 04:34 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Hey Franny. Yes. I took those numbers and crossed then to AC Delco, which led me to Auto Zone. Last pack in Huntsville!!! Thank you!!!!
Old Sep 2, 2017 | 05:36 PM
Drew's Avatar
Pretty sure that's the kit for rebuilding the fuel rail. I suppose if the rings fit, wear them. Standard SK24 is another brand of the same set...
The brown Viton inlet/outlet O-rings are easy enough to find. Parts stores usually have an assortment on the pegs, or you can find them by digging around the websites. Hardest part is if you need more than a pair, since they can be hard to find in quantity.
Old Sep 2, 2017 | 05:47 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
It is Drew, complete set. Which work out since i have the whole fuel rail apart. Ready to assemble tomorrow.
Old Sep 5, 2017 | 06:27 PM
Vader's Avatar
Keep a copy of this handy, and you'll never NOT find an O-ring again:
https://www.parker.com/literature/OR...g_Handbook.pdf
Old Sep 5, 2017 | 06:41 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
for future reference, the o rings that go between the rubber line and the solid lines on the frame rail are "Dorman 800-013 Viton O Rings"
Old Sep 6, 2017 | 07:27 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Thanks all.
I got them at Oriellys and Auto Zone. Bosch Injectors installed, all fuel rail O-Rings, 9th injector O-Ring included. 57K original injectors gone. Car runs super.
Old Sep 6, 2017 | 07:30 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Thanks for that Vader. I also have the book from Parker
Old Sep 11, 2017 | 04:54 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
See the first link in this post:
https://www.thirdgen.org/forums/tpi/...ml#post5962508
I have three FI GM vehicles and it was worth my time/money to put together a kit full of necessary o-rings.
