Tpi
Old Oct 23, 2017 | 02:06 PM
Summy's Avatar
Tpi
I have a 88 wrecked IROC Im wanting to pit the tpi on my 95 Chevy Silverado is there a pinout where I can still use my 4l60e transmission I have the computer and wiring harness to
Old Oct 24, 2017 | 10:44 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Tpi
16197427 ecm ? You will need to tune for the swap as well as jumper the memcal for cylinder select. You might lookup members pro posts he just completed the swap.
Old Oct 24, 2017 | 10:58 AM
Summy's Avatar
Re: Tpi
Is there a diagram where I can repin my factory fuse box in my truck and will that ecm plug up to the factory one or will I had to cut the plugs off
Old Oct 24, 2017 | 11:02 AM
Engine: Lb9
Transmission: M20
Re: Tpi
Isn’t that your oem ecm ? Same as the 16196395 you can piggy back to keep trans control.
Post #6
http://www.gearhead-efi.com/Fuel-Inj...Information-0D
Old Oct 24, 2017 | 11:13 AM
Summy's Avatar
Re: Tpi
Sorry if I sound a little dumb this is the first time I've tried a tpi so I'll have both ECM's in there one for motor and one for trans
Old Oct 24, 2017 | 06:37 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Re: Tpi
im writing up a doc on everything i did and will post on gmt400.com this weekend hopefully.
A 95 silverado like you btw
Old Oct 24, 2017 | 06:56 PM
Summy's Avatar
Re: Tpi
Thank you I'll be sure to check it out tuned performance helped me out a lot to this is the first Chevy Silverado I've done two Ford's one 76 and a 63
Old Oct 25, 2017 | 09:55 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Re: Tpi
Here is what I have so far. I just need to add a bunch of pics and probably clean up any assumptions or misunderstandings ive made.
http://www.gmt400.com/threads/tbi-to...on-mpfi.39486/
randybdis
Oct 22, 2019 12:34 PM
raychappell
Nov 20, 2016 05:29 PM
89irocz355
Oct 2, 2016 06:42 AM
randybdis
Sep 14, 2016 01:57 AM
raychappell
Sep 11, 2016 06:16 PM
