Engine running rough and rich
Old Nov 7, 2017 | 02:20 PM
Driller's Avatar
I have a 1986 TPI 305 camero motor that runs rich. No power on a hill climb or from a dead stop or low RPM's.When the engine come up to around 2,000RPM's it comes alive.
I took off the the new air cleaner and the motor had run better, more responsive.
Im running a Spectre cone style air cleaner with 3'' tubing for proper placement around the engine.
Does this TPI require an Additional air box for an air demanding TPI, or can my MAF sensor be adjusted?
Old Nov 7, 2017 | 03:17 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Engine running rough and rich
I would more suspect EGR was stuck open.....
Old Nov 7, 2017 | 03:19 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Camaro ! , Any error codes ?
Have you checked fuel pressure drop ?
Old Nov 7, 2017 | 04:47 PM
Driller's Avatar
Thanks Guys,
I will Check both the EGR and for pressure drop at the fuel rail.
I will update later.
Thomas Stahel
Feb 8, 2018 02:46 PM
jared1264
Nov 7, 2017 03:34 AM
SRKLEGIN
Oct 29, 2017 02:28 PM
dibella989
Oct 10, 2017 11:25 AM
Frued1961
Sep 30, 2017 09:38 AM
