Washers or no washers on the intake bolts
Old Nov 11, 2017 | 02:47 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Also, locktite or no locktite?
I just picked up from summit - ARP 434-2001
Old Nov 11, 2017 | 02:49 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Washers or no washers on the intake bolts
Liquid Teflon works well, I’d use the washers. If your using this on a tpi unit there might no be enough room between the manifold to runner.
Old Nov 11, 2017 | 03:49 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Any idea why 4 of the washers are thinner, and the bolts they came with are about 1 mm or 2 longer?
Old Nov 11, 2017 | 04:10 PM
Engine: Lb9
Transmission: M20
You might want to install one without the washer and check runner tube clearance. Washers give better clamping power but arnt really needed on the intake.
Old Nov 11, 2017 | 05:19 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
I did - with the washer, there wasnt enough room. So ill have to go without the washer.
Sucks that the front drivers bolt, number 10 i believe, cant find much to grip. I assume because coolant finds its way down there and over time rust can form, messing up the threads.
Old Nov 11, 2017 | 09:05 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Flanged bolts typically do not require washers unless the bolt and corresponding mating surface are of different metals (like you have) OR the flanged portion of the bolt does not have enough contact with the mating surface, like you have. So use the washers. The bolts that are longer can go in the two middle holes on either side since there is just an empty space behind those threads on the cylinder head.
Old Nov 11, 2017 | 10:07 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
I went with no washers. The surface is about the same as the factory bolts.
I dont know what the differences in metal have to do with it. The factory bolts are different than the aluminum intake as well.
Old Nov 12, 2017 | 08:12 PM
NoEmissions84TA's Avatar
Bolts that are too long can bind the pushrod in some locations.
Old Dec 27, 2017 | 07:24 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Sorry I'm late to this one, but in case anyone else finds this thread with the same question.
I used similar bolts on my intake.
What I did was: I installed the runners before tightening the bolts on the fuel rail. With the fuel rail raised a bit it did give enough room to install the runners, whereas with it bolted down the runners would not clear the rail and intake bolts.
