TPI to LT1 Help!!
Car: 88 IROC-Z/00 GTP/05 VUE Redline
Engine: LB9 305/3800 SC/3.5 SOHC V-TEC
Transmission: A4/A4/A5
TPI to LT1 Help!!
I'm planning on ditching my TPI and getting a LT1 intake and having it reworked by John Millican..I found one on ebay out of a vette and it says it comes with everything but the wiring harness. Will I be able to use this? Any and all help is appreciated..
I haven't made a choice on a cam for this new setup...I'm thinking of going with the Trick Flow 23* heads for the swap alot of people seem to be happy with them on a miniram/Lt1 motor. And Right now I have edelbrock TEs headers and RPM series catback..which I'm planning on changing over to SLP or hooker 1 3/4 headers and a mufflex catback with a spintech muffler to let the motor breathe a little better. I'm thinking of either 3.45 or 3.73 gears in the rear. I'm still trying to piece everything together..any comments or ideas?
cobrakiller,
what do you have now??
or are you in the planning stage.
build a short block, buy the heads, build the intake??
if you are a stock 5.7L and adding to it. the manifold swap will
be fine, just no flow because of the stock cam, and your right
there a couple more hours and the cams out.
many ways to attack it, budget, use of car, and availability will
determine a few for ya.
airdeano
airdeano
Right now other than an aftermarket cam my motor is stock internally..I want to just start fresh and get a new cam and heads..What would be a good cam to go with? That would work well with the LT1 setup and the TF heads..
HOT LT4 cam
the HOT LT4 cam would be a fine candidate. short runner fast
ramp profile. will need a loose converter (2500rpm) gears and
a 52mm throttle body. programming will be necessary. the 3.73
will probably be the norm as the torque fall off under 2000rpm
will be noted. so intown and moderate highway will be sluggish.
thats why manual trans is preferred. in a 96 corvette LT4 6-spd
4.10 gear this cam was a neck snapper over stock.
airdeano
airdeano
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Anyone ever try swapping a cam in the car?
I've done 'em on the second gens, and you just gotta lift the motor up about 3 inches, or unbolt the crash bar. I'd imagine on a thirdgen it would be a little tight.
Anyone have any data on the LT1 intakes vs aftermarket TPI stuff?
-- Joe
-- Joe
Originally posted by pxtx
In stead of doing the intake swap, why not just buy a whole LT1? If you modify it to accept a dizzy, you can contol it with what you've got.
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Well, I have the LT1 intake with the LT4 HC. So far, I like the combination. It does rev better than the TPI I had before. Unfortuneately, problems on the dyno led to inconclusive results. I know I have at least 268rwhp and 252ft-lbs of torque, bad considering my previous run.
As for putting in the cam, yes it can be done, but it's a PITA. When I did mine, I put the cam in while the engine was in the car, but I ended up pulling it to redo the heads and install the torque convertor.
And, FYI, I have TFS TW heads, 2700 stall and 3.73 gears.
Rob,
What did you use in this picture for the dizzy spacer? Is this store bought, or did you make it?
http://members.home.net/rcrabine/lt1/DistRing03.JPG
Will this require machining the intake for the spacer to fit correctly?
Thanks in advance,
Paul Tholey
Thanks in advance,
Paul Tholey
Sanjay
Aug 12, 2015 03:41 PM
