Washed engine no crank after.
Old Dec 17, 2017 | 11:07 AM
dmm3369's Avatar
Car: 83 Z28 / 89 IROC
Engine: 350's
Transmission: T5 WC / 700R4
Axle/Gears: Posi 3.73
I washed my engine as I have done many times. It will not start now. I checked the distributor and its dry. I checked for spark at the plugs and it sparks. Fuel pressure is good just checked for fun on that one. It sat all night and dry. I checked the fuses under the dash. Any ideas? Could the control module be bad now from water and still have spark. It almost acts like the injectors are not working. Surly it didn't fry the ecm just by washing the engine.
Old Dec 17, 2017 | 01:30 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Re: Washed engine no crank after.
Any connector missing a seal coulkd have gotten water in it. I don't know if you'd kill the ECM that way, but it'd be just as likely to happen if you'd hit a puddle.
There are some relays underhood, like the fuel pump relay, but you said you have good pressure.
It's unlikely however of you frying the ECM by getting the ECM itself wet as that's behind the dash panel on the passenger's side.
Have you checked the connectors to verify there's no water in any?
How exactly is it acting?
Old Dec 17, 2017 | 02:28 PM
dmm3369's Avatar
Engine: 350's
Just spins over. I swapped my MAF with a spare. Put a new control module in the distributor. I have unplugged most the plugs and still nothing. It does have spark at the plugs. It was running perfect before washing the engine. Its like its getting no fuel to cylinders. Fuel pressure is 40 at the rail and I checked all the fuses. Weird since it all dry. I mean I washed it but not any more than other times. Not sure if any wet sensor or relay would cause it. Its dry now. Also the VATS does not have the light on and it turns over so I don't think thats it.
Old Dec 17, 2017 | 03:38 PM
dmm3369's Avatar
Engine: 350's
Ordered a new ECM to try it 28 years old can't hurt. It will fire on starting fluid. I may just take it out back set it on fire!
Old Dec 17, 2017 | 03:42 PM
Jacobaxeman's Avatar
Car: 1991 Camaro RS
Engine: Hot 355ci
Transmission: Beefed TH350
Axle/Gears: 4:10
Originally Posted by dmm3369
Ordered a new ECM to try it 28 years old can't hurt. I will fire on starting fluid. I may just take it out back set it on fire!
if you have a garage keep it warm for a day or two, it'll start up don't worry, just has to dry out. I've done this too once it does start get it nice and hot
Old Dec 17, 2017 | 04:02 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Put a lamp under the hood and let it dry out. DON'T BURN IT, it will be fine!
Old Dec 17, 2017 | 06:28 PM
dmm3369's Avatar
Engine: 350's
Its stuck outside under the carport. ECM want be here until Wednesday so maybe it will start by then and if so I was putting a new one in anyway as part of the restore. Sure is frustrating when you have cleaned the engine many times and boom want start.
Old Dec 18, 2017 | 11:27 AM
dmm3369's Avatar
Engine: 350's
Let it set 2 days and only way it starts is starter fluid spray. Something killed the injectors all 8. I think it may have fried the ECM. What would kill all 8? I have checked the fuses. The VATS light goes off and the starter turns.
Old Dec 18, 2017 | 11:29 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Check your INJ 1 and INJ 2 fuse.
Old Dec 18, 2017 | 11:43 AM
dmm3369's Avatar
Engine: 350's
Both fuses are good. I didn't change them but visually they appear good. I may swap them out to see.
Old Dec 18, 2017 | 12:26 PM
dmm3369's Avatar
Engine: 350's
Originally Posted by bcmag
check tps voltage.anything over about 4v cranking.....clear flood mode ...no pulse
This fixed my issue YES!!Unplugged and cranked up!!
Old Dec 18, 2017 | 12:36 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
YAY! Glad to hear! Now go wash that engine off!
Old Dec 18, 2017 | 12:47 PM
dmm3369's Avatar
Engine: 350's
lol after all this I am getting better at fixing it when it does break. I went after the distributor but never thought about the TPS.
Thanks for the help. I wanted to post what it was for others who wet the engine
David
Old Dec 22, 2017 | 08:14 PM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
Thanks, I would have never thought of that!!
CamaroStud1988
Aug 8, 2004 02:47 AM
dwillms
Apr 14, 2004 11:41 PM
dwillms
Apr 14, 2004 01:34 AM
grissam88TA
Sep 28, 2003 02:08 AM
