85 IROC MAF ISSUE
Old Dec 22, 2017 | 09:13 PM
sdoyle1's Avatar
Car: 2000 Yukon XL
Engine: 5.4
85 IROC MAF ISSUE
Hello, Working on a 85 Iroc starts and runs (poorly) checking MAF sensor. Went to firewall to check relay and burn off and they are not present. Also unable to find the wiring to reestablish them on the firewall. Any know where the wires originate? Pictures. Thanks has me stumped dont know why they are not present the brackets are their but they and the associated wiring are not.
Old Dec 22, 2017 | 11:16 PM
GeneralDisorder's Avatar
Re: 85 IROC MAF ISSUE
The relays are not strictly required as long as the MAF has switched power when running. The burn off relay only serves to clean the element when activated.
Have you pulled codes, and done any data logging? The ECM will tell you if there are serious circuit malfunctions.
GD
Old Dec 23, 2017 | 06:11 AM
357L98's Avatar
I don't think an 85 has a burn off relay. There is a silver box under the dash that handles that.
Old Dec 23, 2017 | 07:28 AM
sdoyle1's Avatar
Car: 2000 Yukon XL
Engine: 5.4
Ok guys thanks for the help. I will pull codes the check engine light is on. I thought they all had the relay/burn off. Thanks again for the advice
Old Dec 24, 2017 | 10:37 AM
Vader's Avatar
Correct, and that MAF module also switches power to the MAF.
slow_90firebird
May 19, 2008 12:55 AM
Psycho_91Camaro
Apr 17, 2005 03:06 AM
S10Wildside
Mar 28, 2003 07:13 AM
