New valve seals on L98 117k miles. New springs and 1.6 rockers while I'm at it?...
Car: 1989 IROC Z L98 G92
Engine: 5.7
Axle/Gears: 3.27 G92
I have 1989 Z with 117k miles..... Runs great. Long story short, started burning oil @ start up so I am going to replace valve seals. I purchased Fel Pro SS55112, SS72527 and SS72877 valve stem seals.
I have a Comp Cam 08-501-8 installedSpecificationsIntakeExhaustRPM Range:Valve Lash:Valve Timing
uration:Lobe Separation: Duration @ .050" Lift:Intake Centerline:Valve Lift:Lobe Lift:Valve Timing @ 0.006 Lift: with mildly ported intake and runners with stock heads.. Also, gonna put headers on (1 5/8 with 2 1/2 ) inch collectors to help with already installed Magna Flow dual cat exhaust. I was going to put in new springs.
Valve Spring Set of 16 550 Z28 Springs
Valve Spring Specifications:
OD: 1.260"
Closed: 114lbs @ 1.710"
Open: 318lbs @1.210
Coil Bind@: 1.160Spring Type Single with damper
Valve Spring Retainer
11/32 X 7 degree
1.200x .860
Valve Lock
11/32 X .377 X 7 degree single groove
I am also going to install Competition Cams 1418-16 Magnum Self-Aligning Roller Rockers 1.6 ratio, 3/8" Stud. Any thoughts or coments on this set up would greatly be appreciated. Amfornal
uration:Lobe Separation: Duration @ .050" Lift:Intake Centerline:Valve Lift:Lobe Lift:Valve Timing @ 0.006 Lift: with mildly ported intake and runners with stock heads.. Also, gonna put headers on (1 5/8 with 2 1/2 ) inch collectors to help with already installed Magna Flow dual cat exhaust. I was going to put in new springs. Valve Spring Set of 16 550 Z28 Springs
OD: 1.260"
Open: 318lbs @1.210
11/32 X 7 degree
1.200x .860
Valve Lock
FART_NUGGETS
Oct 31, 2017 12:33 PM
86FyrBrd
Jan 17, 2013 07:34 PM
87GTAspeeder
Apr 22, 2005 11:41 PM
