What is the difference between the intake manifold TPI
Hello I want to buy a manifold but you got more than a number for the same piece is there among them
I want to install it on the 305 TBI engine
https://www.ebay.com/itm/85-Corvette....c100011.m1850
ــــــــــــــــــــــــــــ
https://www.ebay.com/itm/1986-Corvet...-/391431742729
https://www.ebay.com/itm/162807902829
What is the difference between them I want to install on the TBI 305 engine
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: What is the difference between the intake manifold TPI
There was a slight bolt pattern change between 85 and 86 vs 87-92. I am not sure what is different on the corvette version.
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
center 4 bolts (2 on each side) on Corvette were different angle. You will see some intakes drilled for both.
Formula&Z28Toys
Aug 1, 2003 12:17 PM
