1989 TPI Intake on 1986 heads?
Car: 1989 Iroc-Z Convertible
Axle/Gears: 2.73:1
Was looking at these heads for a possible budget head/cam swap, but they use the straight center intake bolts from 1986 and earlier.
Can my 1989 base be modified (drilled) to work with the straight center bolt holes, or do I need to budget for a new lower intake as well?
Here are the heads:
https://www.summitracing.com/parts/wrl-042650
Here are the heads:
Re: 1989 TPI Intake on 1986 heads?
Yes it can be re drilled.
Axle/Gears: 2.73:1
Cool, anything special need to be done so the bolt head will sit flush?
The bolts might not sit flush without a bushing. There are a few styles.
https://www.carid.com/professional-p...mpn-52110.html
You might consider a higher flowing base for performance the stock base is restrictive.
https://images.search.yahoo.com/imag...sigt=11l02tvvu
Car: 1989 IROC
I am going to be doing this in the next few days. was wondering dose any one have any photos of the holes drilled out and realigned
Thank you
Blinky
Thank you
Blinky
Car: 1989 IROC
I did mine today I used a die grinder to contour the top flat and a mini die grinder to extend the holes both using non ferrous carbide burs.
I was thinking about welding up the un used part of the holes but I think it should be fine seeing as the after market ones are slots also.
Blinky
Axle/Gears: 2.73:1
Thanks guys. Still no idea what I will ultimately do here, now Im thinking going with some Vortec heads and a matching TPI base. Maybe I should just leave it alone until it blows up......
utilityguy2
04-27-2012 06:43 PM
LARRY Hedge
09-02-2002 07:45 AM
