Replacement Injector not as long as factory
Old Feb 11, 2018 | 10:06 AM
67restoproj's Avatar
Car: Players Challenge 1LE-R7U
Engine: LB9
Transmission: 5spd
I bought a set of replacement re-conditioned injectors for my 89 Iroc. Problem is they are not as long as the factory installed. When I re mount the fuel rail the injectors do not fully seat in the manifold. I was told by the counter man that it shouldn’t be an issue as long as it is in part way it’s still sealed by the o ring....really??? Your thought please!!
Original is left (grey)
Old Feb 11, 2018 | 10:28 AM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Re: Replacement Injector not as long as factory
I'm thinking the replacement is the wrong part. And not to trust parts counter guy's word.
Old Feb 11, 2018 | 01:07 PM
Abubaca's Avatar
I think it'd PROBABLY be ok, but I wouldn't take the chance. -and if the parts guy tells you it'll be fine, then you KNOW it won't be.
I'd return 'em and check out Southbay. They're a sponsor and they have injectors corrected for proper length. LOTS of us here running them successfully including me.
Old Feb 11, 2018 | 02:45 PM
Drew's Avatar
Look like LT1 injectors. And yeah, there are a bunch of injectors out there that are 1/8" shorter. It's not a big deal, just don't use the locking clips, and don't push them as deep into the rail when you install them, and they're supposed to work. The alternative is to buy injectors that are actually intended for the application.
Go on Rock Auto and see if the replacement injectors you have are listed as a replacement for your car, and go from there.
Old Feb 11, 2018 | 07:07 PM
Engine: LB9
Transmission: 5spd
They list a first and second design. I believe the second design is the smaller. Not sure why. Not willing to take a chance. The retainer clips are discontinued also... grrrr
Old Feb 11, 2018 | 07:10 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I agree with drew, you can get clips off eBay or the Bosch 3s don’t use them. I haven’t seen a length change in the f body multecs.
Old Feb 11, 2018 | 07:12 PM
Abubaca's Avatar
They're all over. Used, new...you name it.
https://www.ebay.com/itm/Fuel-Inject...BaSCLp&vxp=mtr
Old Feb 11, 2018 | 07:47 PM
Engine: LB9
Transmission: 5spd
thanks guys just ordered some off ebay
Don Christensen
Jan 5, 2012 10:49 PM
SillyWabbit
Feb 22, 2003 06:15 AM
The Dirty Bird!
Mar 1, 2002 04:29 AM
