TPI: Dual vs. Single Throttle Bodies
Old Feb 14, 2018 | 03:19 PM
newbvetteguy's Avatar
Car: 1979 Corvette L82
Engine: Gen1 SBC 350 L82 4 bolt mains 010
Transmission: Monster 4L60e 2wd 1997 PWM capable
Axle/Gears: 355
I'm really curious why most TPIs and even aftermarket TPIs seem to almost always have dual throttle bodies vs. single throttle bodies.
If you had a dual throttle body and then swapped to a single throttle body with the same CFM Flow #'s what would be the difference??!?
Adam
Old Feb 14, 2018 | 04:23 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Re: TPI: Dual vs. Single Throttle Bodies
Depends on the car. From absolutely nothing all the way up to negligible.
Old Feb 14, 2018 | 04:36 PM
Axle/Gears: 355
Hahaha awesome response.
Good to know that I shouldn't sweat it much either way.
But what do you expect that difference would be?!? (Qualitatively.)
Adam
Old Feb 14, 2018 | 05:14 PM
Engine: LB9
Axle/Gears: 3.08
The high end of negligible is by definition not worth considering. So I won’t.
Old Feb 15, 2018 | 01:58 PM
Axle/Gears: 355
Yet you took the time to make this comment with a value ranging from absolutely nothing to negligible. #Ironic
Old Feb 15, 2018 | 02:28 PM
Engine: LB9
Axle/Gears: 3.08
Still looking for a different answer? If you want exact numbers throw a dart at a dartboard, whatever you get divide it by two. That's your EXACT hp number you can expect at the high end. For the low end, repeat the scientific dart experiment. This time instead of dividing by 2, simply subtract the number you get from itself. This is the low range.
And just to make sure all bases are covered, repeat magic dart experiment. This time take the number you get and divide by negative 2. This is your exact loss expectation.
If you need a formula instead:
Z=((f/2)+(s/-2)+(t-s))/3.14
Simply solve for Z where f = your first dart, s = your second dart, t = your third dart.
Funny thing about this equation is that it also gives me the exact amount of time that should have been spent replying to this thread in the first place.
greasegrenade
Feb 8, 2017 10:16 PM
rlthrasher
Jun 26, 2014 11:43 PM
327_TPI_77_Maro
Dec 4, 2006 03:41 PM
