NEED HELP TPI SWAP
Old Feb 19, 2018 | 11:12 PM
Ajhicks's Avatar
Want a title? Post!
NEED HELP TPI SWAP
I have a 355 motor that I'm putting a tuned port injection system on from a 1986 Camaro I have a Doug Hebert cam in it
Ad-285/290
D @50 230/235
Lift 488/48
lobe center 108
​​Summit cast iron Heads
2.02
72cc
165cc
​​​1.6 roller rockers
My question is will I be able a tune the computer to work with the cam I have already without changing it?
Old Feb 25, 2018 | 10:35 AM
Ibazzabar92's Avatar
Car: 1992 RS/89 Formula
Engine: 305 TBI/350 TPI
Transmission: auto
Axle/Gears: 2.73/3.08
Re: NEED HELP TPI SWAP
Ad-285/290
D @50 230/235
Lift 488/48
lobe center 108
2.02
72cc
165cc
I would swap it out to a computer compatible cam with a Lobe seperation angle of at least 112 or higher and a little bit less duration, Keep it under 220.
Old Feb 25, 2018 | 04:25 PM
Vader's Avatar
Since the '86 TPI system uses a MAF, it is probably going to be a lot more forgiving. It should at least run respectably until the pedal hits the floor. At that point some tuning will probably be in order - Especially with those large-chambered heads.
davidopliger
Feb 3, 2025 09:30 AM
Bimma86
Dec 3, 2004 02:27 PM
chuck6860
Jul 23, 2002 09:36 AM
