L98 BUILD OPINIONS
Old Apr 4, 2018 | 09:29 PM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
L98 BUILD OPINIONS
I hate when unexpected stuff comes up, lol! Reason I'm throwing this out there is cause business is good(thank you Trump!) and i have a little expendable income this quarter. Before the holidays I was looking to build a motor for the wife's avalanche. Pretty sure that idea is going by the wayside(picked up a duramax pickup needing a new motor that's probably gonna be her new ride), so back to some upgrades on the IROC. So here's the dilemma... I'm not gonna do a full motor build this year, but would like to use parts I already have. I hate doing things twice, but I really want a good running car this summer. Have the following parts(which I think would make a good running car)... SLP headers, LPE 219 cam, and a set of (don't laugh) pro comp 190(5?) heads. Ordered 3.70 gears for the 9 bolt. I know there's better heads and cams out there, but I can use what i got without a full motor build. I have no problem spending a weekend installing what I got cause it may be another year or 2 till I do a full motor build. What would you guys do in my situation?
Old Apr 5, 2018 | 06:10 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: L98 BUILD OPINIONS
You can throw it on now no problem if those heads have proper hyd roller springs on them and they check out ok.
Wont run super well if you keep stock tpi on it but it should pick up alittle bit and sound better
Will need a custom tune
Old Apr 5, 2018 | 09:56 AM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
Intake is already upgraded
Old Apr 5, 2018 | 11:21 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Then run it lol it will be faster than stock
Old Apr 5, 2018 | 01:34 PM
Abubaca's Avatar
If you go ProComp...make SURE you have 'em checked. Casting is pretty poor.
Old Apr 5, 2018 | 07:13 PM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
Yea I know... Got them pretty cheap, but was an impulse buy and didn't do any research till afterwards. Thinking about selling them and getting some 1040's from Rick. And yea, I'll be getting back in touch with you Justin about tuning.
Old Apr 6, 2018 | 07:10 AM
Abubaca's Avatar
I wouldn't worry about using them....I'd just make sure I had a machine shop go over them....valve guides etc. etc. I have a friend using them and they run and perform great, but he definitely needed a little clean up at the machine shop. If you already HAVE em, I'm not sure I'd SELL them, just do your due diligence.
I mean....AFRs are AFRs though...so I'm not trying to talk you OUT of those!
Old Apr 6, 2018 | 07:24 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Couple hundred bucks you can have them checked out, proper valve jobbed, guide clearance set and decked square. Take them to P&R in greensburg if you are out this side of pa
Old Apr 6, 2018 | 09:11 AM
Ty92Z's Avatar
Car: 1992 Z28 1991 RS
Engine: LB9 LO3
Transmission: 5 speeds
Is there much gain in going with the Procomp over 083’s? I have a new set I bought bare several years ago and assembled with PBM stuff. Was considering throwing them on an L98 I’m building for my 92Z. Of course I would still have my machine shop go over them for added insurance. Zyapoint, I hope I’m not offending you by asking on your thread.
Old Apr 6, 2018 | 09:36 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
If the pro comps are machined properly and valve seat seals fine and guide clearance is ok and you dont have any other issues then yes they would be better than 083’s
If you need a budget casting try the assault racing head or proheader. Same thing just put decent valves and springs in
Old Apr 6, 2018 | 10:30 AM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
Maybe I will do that. I am actually kinda curious to see how fast the car goes with what little money i got into it so far, lol. Thanks for the recommendation of P&R. Been looking for a shop to check out my duramax heads. Would work out good if I could have them do both sets. That being said, what springs should I use with the 219 cam? And don't worry about it Ty92z, I don't get offended, lol. Besides, we're here to share info right?
War_Eagle
Jun 4, 2006 07:11 PM
305q_ta86
Oct 27, 2004 09:09 PM
kamaroirock
Aug 5, 2004 11:11 PM
Matt86t/a
Aug 1, 2003 02:02 PM
