Small miss @ idl, (only with esc wire connected)
Old May 23, 2018 | 12:11 AM
happyhapka's Avatar
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
86 w/ 350 swap tpi has a slight miss, sounds like popcorn out the exhaust but runs ok..
but it only misses when the esc wire is connected, with it unplugged it runs very smooth(no miss)
so i believer that puts it around i need a new esc/ or knock sensor..
maybe they never swapped that out when they did the 305 to 350 swap?
any ideas?
Old May 23, 2018 | 04:47 PM
happyhapka's Avatar
Re: Small miss @ idl, (only with esc wire connected)
Any ideas?
Old May 23, 2018 | 05:08 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Could be too advanced reset timing with the ESC disconnected
Old May 23, 2018 | 05:19 PM
happyhapka's Avatar
With it disconnected its at 6* tdc
Old May 23, 2018 | 05:29 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
sensor then.
Old May 23, 2018 | 06:11 PM
happyhapka's Avatar
Originally Posted by mmadden55
sensor then.
what sensor?
the knock sensor? Or the esm or icm?
Old May 24, 2018 | 07:46 AM
happyhapka's Avatar
Or perhaps ill play with the timing?
wouldnt the timing be different on a lower compression gm goodwrench 350? Its cam is the larger one.(not like it matters with the 76cc heads)
but would 6* still be the base for that?
or would it be lower or higher due to high and low compression?
Old May 24, 2018 | 10:21 PM
happyhapka's Avatar
Could this be the problem?
Old May 25, 2018 | 12:57 PM
happyhapka's Avatar
Bump
mike1986fyrbird
Feb 10, 2015 11:21 AM
Slow2.8
May 21, 2009 07:14 AM
roguecoxnet
Apr 12, 2009 04:03 PM
jackballs529
Dec 7, 2004 12:55 PM
350turbo411
Apr 5, 2002 08:53 PM
