89 camaro problem
Car: 1989 camaro iroc-z
Engine: 350 tpi
89 camaro problem
So I got my engine rebuilt and the ship didnt do a great job. I was driving it and then it lost power. I would floor it and it was unresponsive and it smelled like gas can it be a bad mad? Here's a link on how it sounds thanks
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 89 camaro problem
So I got my engine rebuilt and the ship didnt do a great job. I was driving it and then it lost power. I would floor it and it was unresponsive and it smelled like gas can it be a bad mad? Here's a link on how it sounds https://youtu.be/lDnFoyCM_sI
thanks
thanks
Mad or do you mean maf ?
Stock multec injectors ?
Engine: 350 tpi
Engine: 350 tpi
I had a friend check it with his scanner and it said mass air flow sensor and connector, but also Ive noticed that when I turn on my head light and fog light the engine wants to turn off and it idles crazy. Could it be a bad alternator? Thanks
Engine: Lb9
Transmission: M20
You can certainly have the alternator tested most auto parts stores will do this for free.
You might want to retrieve the codes and follow the flow chart for Maf diagnostic.
33, 34 and 36
http://chevythunder.com/fuel%20injec...0pg%20a.htm#33
Chevy thunder also has flow charts for these codes
http://www.chevythunder.com/maf_code_33.htm
http://www.chevythunder.com/maf_code_34.htm
http://www.chevythunder.com/maf_code_36.htm
33, 34 and 36
Engine: 350 tpi
33, 34 and 36
33, 34 and 36
Engine: Lb9
Transmission: M20
Btw you can easily check your own codes with a paper clip.
https://www.obd-codes.com/faq/read-g...codes-free.php
Shepp84Z28
Apr 8, 2019 10:36 AM
squirrelybird
Oct 16, 2002 08:24 PM
