Super Ram questions
Old Aug 2, 2018 | 02:13 PM
87350gtanj's Avatar
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
Super Ram questions
hello all, will be doing a 350 swap soon and installing my accel super ram I’ve had in storage. My two questions are what’s a good cam to go with for installing the super ram and also what size injectors should be used in the swap as well since I’m sure the 305 tpi injectors are too small psi wise
Old Aug 2, 2018 | 02:21 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Super Ram questions
Depends on your power goals, but around 30lb injectors are a good bet.
Cam also depends on what heads you are using. If you are using Trickflow or AFR 195, Look into a Comp 268 or 280 XFI, or LPE219 if you want to stay smaller. The biggest thing on your build is going to be tuning it. So the more information you can provide on the rest of the parts you are using, the better the recommendations we can give. For all we know at this point you could be using stock heads and exhaust. That would dramatically narrow your cam choices and such.
Old Aug 2, 2018 | 02:24 PM
87350gtanj's Avatar
Going to be running headers coated if u could recommend a set with air tubes and a y pipe of coarse as far as heads looking into aluminum not sure what brand or size yet again recommendations would be great
Old Aug 2, 2018 | 02:32 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Your best bet is to go into the socal forums and look at their builds. They have some really good builds you could copy.
Personally I would go AFR 195, Dyno Don 1 3/4" headers, and cam all depends on your power goals, ability to tune, and driveability.
We really need to know your power goals so we know what you're after...
88IROC5.7
Nov 10, 2007 07:29 AM
jdaniel
May 9, 2003 08:06 PM
bzznczzn
Aftermarket Product Review
Nov 21, 2000 10:41 AM
