91 z28 stalling under load
Old Aug 6, 2018 | 12:13 AM
DASHEKY's Avatar
I have a 91 z28 305 tpi, I’m about to give this sucker away. I’ve been having a issue with the car falling on its face after reaching operating temps under load, in reverse and also cruising at 30 letting off the throttle slowly. The car idles like a dream and when it hiccups under load the car snaps back and runs smooth from anywhere between 30-45 seconds then falls on its face again.
My buddy gave me a great price on it after her had a cam installed this issue persisted, uppon purchase I installed a new distributor, wires, fuel pump, fuel filter, injectors 19lbs, fpr, iac valve, vacuum lines, tps sensor manifold air temp sensor , i found both temp sensors disconnected and 3 grounds disconnected. Any ideas?
Old Aug 6, 2018 | 08:57 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Re: 91 z28 stalling under load
Removed
Old Aug 6, 2018 | 09:08 AM
DASHEKY's Avatar
TPS is reading .64 closed and 4.24 wot. I actually did put a ac Delco ECM. Sorry I forgot to mention that. Also the thing has no codes. Never one time has the light came on after start up
Old Aug 6, 2018 | 09:10 AM
DASHEKY's Avatar
I agree it has to be electrical. The Tach reads like 4500rpms at idle when in reality it is about 850 at idle
Old Aug 6, 2018 | 11:20 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
That is a high voltage for idle BTW. Should be around .54V but I don't see that being a huge issue.
I think the best thing you can do is get something to scan/log with and get 30 sec to a minute of data before and after the incident and capture the incident. This should allow you to see what is changing and give you a path to start diagnosis on.
Old Aug 6, 2018 | 11:36 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
the spec for 90-92 tpi is .66-76vdc. The tach sounds like a separate issue.
have you checked your fuel pressure ?
https://www.thirdgen.org/forums/tran...ds-double.html
Old Aug 6, 2018 | 11:57 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Good to know... I have not worked on many of the SD or later cars. Learned something new today.
Old Aug 6, 2018 | 12:22 PM
DASHEKY's Avatar
Before I changed the injectors and fpr key on fuel pressure spiked to 43 and bled down 1 pound per minute. Then really fast after 25
Old Aug 6, 2018 | 12:24 PM
DASHEKY's Avatar
After I changed everything it’s steady at 42 lbs over night
Old Aug 6, 2018 | 12:26 PM
DASHEKY's Avatar
Old Aug 6, 2018 | 12:56 PM
DASHEKY's Avatar
Btw I wasn’t just throwing parts at it. Everything had a reason, for instance the cap and rotar had corrosion, the icm was over heating and the heat sink was damaged, also why not throw a entire distributor with the new cam just my personal opinion. The car is 27 years old. Does not hurt to change the sensors entirely. The tps had dead spots while checking voltage with my fluke meter. The IAC valve was really rusty. The intake air temp sensor was really rusty after I wiped the sucker off. The fuel pump I did cause the sending unit was not working at all so why not throw 60 pump in the same time? Wires change them every 30k and Spark plugs aswell.
Old Aug 6, 2018 | 12:57 PM
DASHEKY's Avatar
Also I tried a new ecm cause of the tach issue. Good to know a simple resistor will cure that, thanks for the link 👌🏼
Old Aug 6, 2018 | 01:45 PM
DASHEKY's Avatar
I mean the car has 82,000 miles, it was never driving which IMO is the worst for any vehicles mechanical system...
Old Aug 6, 2018 | 11:10 PM
DASHEKY's Avatar
Thank you for the tip on fixing the tach, resistor installed in like 20 mins. Tach reads steady 800 at idle. So I did notice the fans do not kick on and the car gets pretty hot. If I’m not mistaking that is the sensor passenger side between cylinder 6 and 8? The “fan switch” ? Could this be causing the issues while driving? Does the ecm use that info from the fan switch for air fuel mixtures?
Old Aug 7, 2018 | 11:31 AM
Engine: Lb9
Transmission: M20
The sensor between 6 & 8 is the secondary fan switch. The cts in the front on the intake is used for cools start enrichment and correction once in closed loop.
Old Aug 7, 2018 | 11:37 AM
DASHEKY's Avatar
@tuned performance...
thank you for that info, I completely overlooked the thought of the primary CTS. The fans work when I jump the pins to read the codes but never when the car is warm. I’m getting a snap on computer from the snap on guy today so I can scope this sucker with the eagles eye
Old Aug 7, 2018 | 11:39 AM
DASHEKY's Avatar
So from my research the fan switch is jest a thermostatic switch once the car hits 220 it kicks on till the car cools down to 200-211 degrees? Thermostatic switch ?
Old Aug 7, 2018 | 12:04 PM
Engine: Lb9
Transmission: M20
Usually when the cts fails you get a code 15 . The fan switch is a thermal switch.
iirc the map kpa should be from 40-60 Kpa at idle. You have steady vacuum at idle with the cam swap ?
Old Aug 7, 2018 | 12:41 PM
DASHEKY's Avatar
I haven’t checked the vacuum I will have to get a gauge aswell from mr snap on
Old Aug 9, 2018 | 02:10 PM
Wickydooda's Avatar
When I first got my car it would stall when it down shifted and hit over 3,000 rpms. Changing the oil yielded a "rotten egg" smell in the oil which indicates a bad catalytic converter. Deleting the cat solved both problems and allowed the exhaust to flow out at an optimal rate, so it stopped stalling at high rpms.
Old Aug 12, 2018 | 12:32 PM
DASHEKY's Avatar
My cat is deleted on the car aswell
Old Aug 12, 2018 | 12:33 PM
DASHEKY's Avatar
@tubeport performance, my map kpa goes close to 80 when the car starts to stumble during driving and I think it goes above 60 at idle for sure
Old Aug 12, 2018 | 12:57 PM
Engine: Lb9
Transmission: M20
I think I’m mistaken on the map values
z28romance
Jul 10, 2011 02:24 PM
colonboy14
Sep 8, 2004 03:41 PM
88IROC350TPI
Feb 25, 2002 11:45 PM
89 CamaroIROCZ
Aug 1, 2000 10:52 PM
